yes or no?
Old Nov 22, 2003 | 12:06 PM
Carpediem291's Avatar
Default yes or no?
To install itr front sway bar on 1992 si HB, it is necessary to swap out my LCA with an Integra LCA, correct?
Old Nov 22, 2003 | 01:20 PM
chad's Avatar
Moderator
Default Re: yes or no? (eEKEGg)
yes and no.....
Old Nov 22, 2003 | 01:21 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eEKEGg &raquo;</TD></TR><TR><TD CLASS="quote">To install itr front sway bar on 1992 si HB, it is necessary to swap out my LCA with an Integra LCA, correct?</TD></TR></TABLE>
actually no....since you have an si it should have a sway bar already on....should be same mounting points for both si and itr....are you really sure you want an itr bar on the front??
Old Nov 22, 2003 | 01:24 PM
Default Re: yes or no? (chad)
what's wrong with an itr front sway bar?
eg6sir88
Suspension & Brakes
Aug 10, 2007 07:02 AM
jeffk182
13
Oct 26, 2006 01:32 PM
EMphaticONE
Nov 25, 2004 08:57 AM
FrostyDC4
Apr 28, 2004 02:09 PM
nuspeed27
Sep 18, 2002 11:01 AM
