Just installed the OEM foglight kit. Question??
I need to know how to aim the foglights. The instructions do not cover this part. How far from a wall should I aim them and how far up should they be? Thanks!
When I first adjusted mine, I took a friend to a parking lot at night... I turned on the low beams and noticed where they made the most ground contact. As I stood several dozen feet in front of car, I had him adjust them until the fogs illuminated the area between the car and the low beam spots. It's whatever you're most comfortable with, (as long as they don't blind oncoming cars).
theres a screw with a spring,,,just look around and im sure that you will see it,,after you get it adjusted you should adjust the headlights a bit higher than they are now,,,you will get a better visual on things....oh yeah if your planning on putting new lights in them dont go higher than 55 watts
PhatboyNYC
Apr 16, 2002 01:15 AM
