do i need to break-in a 6puck clutch ??
Old Nov 22, 2003 | 12:47 AM
Cyber ITR's Avatar
Default do i need to break-in a 6puck clutch ??
i just wondering if i have to break-in a 6puck clutch, i know i do if i have an organic material clutch disk
thanks
Old Nov 22, 2003 | 01:01 AM
integra_gsr98's Avatar
Default Re: do i need to break-in a 6puck clutch ?? (Day Walker)
I never have. Hell I've never broken in any clutch haha.
I put about 20k miles on one and never broke it in. Only replaced it when I rebuilt the motor.
Old Nov 22, 2003 | 01:37 AM
PM-Performance's Avatar
Default Re: do i need to break-in a 6puck clutch ?? (integra_gsr98)
I would to be safe.
Old Nov 22, 2003 | 05:17 AM
shermanyang's Avatar
Default Re: do i need to break-in a 6puck clutch ?? (itr206)
i never broke in my 6 puck. just didn't drive it hard for a few hundred miles.
Old Nov 22, 2003 | 06:19 AM
quickergixxer's Avatar
Default Re: do i need to break-in a 6puck clutch ?? (shermanyang)
ceramic 6 puck clutch does not need to be broken in. most organic types or kevlar should be broken in, or so ive been told
by the way what kind of disc do you use integra_98gsr
Old Nov 22, 2003 | 08:53 AM
Default Re: do i need to break-in a 6puck clutch ?? (quickergixxer)
ACT unsprung ceramic 6 puck.
I've never been a fan of clutch breakin. Drive it around the block and make sure it is engaging and disengaging properly and then rail the **** out of it.
Only major clutch problems I've had have been stripping the splines on the clutch disc and having an ACT pressure plate collapse. Both of which were due to a faulty disc and pressure plate.
Hoosier Daddy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">I would to be safe. </TD></TR></TABLE>
Old Nov 22, 2003 | 09:38 AM
JDogg's Avatar
Default Re: do i need to break-in a 6puck clutch ?? (Hoosier Daddy)
if its not organic you dont need to break it in
Old Nov 22, 2003 | 12:02 PM
yellowhonda88's Avatar
Default Re: do i need to break-in a 6puck clutch ?? (JDogg)
Yea, i only break in organic full face disks, those stopped holding long ago. I have a ceramic 4 puck now, but i drove it normal for about 50 miles due to the face that i didnt resurface the FW because it only had about 4k on it from my other clutch. But basically, I just make sure its holding, and then its ***** to the wall from there.
Brett
Old Nov 22, 2003 | 12:32 PM
tegasaurus's Avatar
Default Re: do i need to break-in a 6puck clutch ?? (yellowhonda88)
yeah, i never REALLY broke mine in. I just didn't drive it hard or let it see boost for about 300 miles... but then again it only lasted 3000 miles, Thanks act
Old Nov 22, 2003 | 12:36 PM
Default Re: do i need to break-in a 6puck clutch ?? (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">yeah, i never REALLY broke mine in. I just didn't drive it hard or let it see boost for about 300 miles... but then again it only lasted 3000 miles, Thanks act </TD></TR></TABLE>
lol, hey same here...it only lasted me a good 4k miles!!
Old Nov 22, 2003 | 01:25 PM
5thgencivic's Avatar
That's why I went with a street disk. Hopefully it holds my power goal though.
Old Nov 22, 2003 | 01:35 PM
rioninja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">if its not organic you dont need to break it in</TD></TR></TABLE>
Thats correct. Puck style disks wont glaze over like organic or kevlar disks can.
(unless exposed to oil). A few slips is all they need to be broken in. They will
just squeal for a little while sometimes while they are wearing in,
expecially if your pressure plate or flywheel arent perfectly flat.
Old Nov 22, 2003 | 01:55 PM
tegasaurus's Avatar
Default Re: do i need to break-in a 6puck clutch ?? (rioninja)
the reason you break in discs is to heat treat the springs also, and since you're using an unsprung disc no warm them up before use as a break in
Old Nov 23, 2003 | 11:00 AM
Hahaha, i am still trying to get used to the lovely chattering when i try to slip my 4 puck ceramic sprung hub, I still cringe every time...lol
Brett
Old Nov 23, 2003 | 12:56 PM
TurboR1391's Avatar
Break it in lol *ROFLMAO.
Old Nov 23, 2003 | 12:57 PM
2K_TEG's Avatar
Default Re: do i need to break-in a 6puck clutch ?? (TurboR1391)
just drive normal for about 500 miles, then beat the **** out of it from there on out.
KYle
Old Nov 24, 2003 | 12:08 PM
Default Re: do i need to break-in a 6puck clutch ?? (2K_TEG)
But wht if driving it normal, is beating the **** outa it....lol
mskansan
May 9, 2008 03:53 AM
harrykong
Aug 26, 2006 07:14 AM
DC-4-Drew
May 13, 2004 04:19 AM
2000turbosi
Nov 3, 2003 06:20 PM
ActiveAero
Jan 7, 2003 04:25 AM
