things to do while the head is off?
Old Nov 21, 2003 | 06:20 PM
Yosshaa's Avatar
Default things to do while the head is off?
i have an ls.. im doin a head swap this next week. what should i do while i hae the head off the block... is there any cleaning i can do to the piston, walls etc? i want to get the cylinders measured to see what kinda of pistons i will need in the future (standard or oversized) would this be a good time to get an idea?... i've researched and it seems that block guards are considerd a waste of time.. soo what else?
cliffnotes: while head is off block what should i clean or what matinace work can i do to the block? what should i look i for? (its a ls engine)
Old Nov 21, 2003 | 07:28 PM
magnum's Avatar
Default Re: things to do while the head is off? (ambition)
well one thing you can do is if you are going to put an underdrive pulley on your alternator then no better time. Very easy access. You can also remove the carbon deposits on your piston tops. Other than that get a B16 or B18 head for the LS-Vtec!!!!!!!!
mon.jar94
May 20, 2013 07:42 PM
ITRnorway
Nov 16, 2006 01:54 PM
92hatchattack
Engine Machining & Assembly
Sep 1, 2006 02:59 PM
Brian_92GSR
Aug 27, 2002 01:25 PM
