b16a in an EG?
Old Nov 21, 2003 | 03:53 PM
type Gendy's Avatar
Default b16a in an EG?
Any of you guys have a first gen b16 in a 92-95 hatchbacK??
Is it worth the hastle if you have the motor?
Old Nov 21, 2003 | 04:00 PM
lsvtec hatch05's Avatar
i have in there right now, tomorrow it is coming out for a lsvtec swap. it is for sure a horsepower gain and vtec is always awesome to have, but if you have some kind of money to play with i would rather go with a b18 instead of b16, the b16 is just sooo weak in torgue and power on the bottom end. just my 2 cents
Old Nov 21, 2003 | 04:08 PM
Eyes Only's Avatar
Default Re: (lsvtec hatch05)
a b16 is good for starters
Old Nov 21, 2003 | 04:10 PM
2000blackgsr's Avatar
Default Re: (Night_Ryder)
A b16 isn't bad, but the first gen will come with the cable tranny so you'll need to get a kit to make it work.
Old Nov 21, 2003 | 06:19 PM
619_eg's Avatar
b16 heads are great to match up with ls blocks... go ls vtec
Old Nov 21, 2003 | 06:23 PM
type Gendy's Avatar
Default Re: (619_eg)
I have a b16a, and i am strictly a crx guy. But i cant find a new one, and i need a new shell ASAP. So i would pick up an EG as a temporary alternative. I dont plan on buidling a motor because "b16's aren't good for starters." My questions is more or less, is it worth putting a first gen with cable tranny into the car. Is there any problems i may run into doing this.... And i am very happy with my torqueless wonder by the way Little help from a t3/t4.
Modified by sick hatchem at 2:35 AM 11/22/2003
Old Nov 21, 2003 | 07:10 PM
dantastic's Avatar
i have a b16a sir-1
-gsr tranny
-integ mounts
-obd1 everything
too slow for me
Old Nov 21, 2003 | 10:33 PM
type Gendy's Avatar
Default Re: (dantastic)
Time to piece a kit together for it.... Do you think you can pm with me with some more detials, ie. wiring, gsr hydro tranny?
Thanks
Old Nov 22, 2003 | 12:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">i have a b16a sir-1
-gsr tranny
-integ mounts
-obd1 everything
too slow for me</TD></TR></TABLE>
this is exactly why my b16 comes out today and ls vtec goes in today
Old Nov 22, 2003 | 12:50 PM
sohcvtec1995's Avatar
a b16 is more of a track motor. track as in road racing. thats just what i think.
Old Nov 22, 2003 | 01:17 PM
chad's Avatar
Moderator
Default Re: (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">a b16 is more of a track motor. track as in road racing. thats just what i think.</TD></TR></TABLE>
b16 ran a 8.6 at the strip last night....2200 lb hatch...just some info for all the b16 haters
Old Nov 22, 2003 | 05:36 PM
type Gendy's Avatar
Default Re: (chad)
I just dont see why you would spend an extra $1800 for 10 more hp and a bit more torque. For that price you have a quality turbo kit waiting ot be installed.
Back to topic: Is it that hard to change the car to a cable tranny?
Old Nov 22, 2003 | 05:39 PM
The Internet Tough Guy's Avatar
Default Re: (sick hatchem)
first, i know almost nothing about the b series.....
second, is it true that an itr tranny is a b16b with a lsd and a different final?
third, is it true that an itr head is just a b16 head with some work done?
Old Nov 22, 2003 | 05:52 PM
chad's Avatar
Moderator
Default Re: (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 &raquo;</TD></TR><TR><TD CLASS="quote">first, i know almost nothing about the b series.....
third, is it true that an itr head is just a b16 head with some work done?</TD></TR></TABLE>
first.....i know alittle....not everything
second...depends on the year of the tranny....
b16b tranny is a 4.4 final drive tranny with lsd (not sure of gear ratio's)
b18c5 pre 98 tranny's are 4.4 with lsd
b18c5 after 98 are 4.785 with lsd (reason being they went with 16 rim package (this is only for JAPAN 98 or newer itr tranny's, US tranny's remained 4.4 with lsd and a closer 4th and 5th gear))
third YES a b18c5,b16b and b16a heads are from the same casting (PR3) some of the earlier C5 heads were hand ported and polished and flowed better (from the factory) but later C5 (newer) were done on the CNC or by a machine
hope that helps
team213
Apr 4, 2004 03:18 AM
djnoclue
Jun 8, 2003 05:47 PM
Sleeping4drLS
16
Feb 23, 2003 06:02 PM
blownsi
Apr 22, 2002 11:15 AM
locass316
Apr 18, 2002 09:17 PM
