b16a in an EG?
i have in there right now, tomorrow it is coming out for a lsvtec swap. it is for sure a horsepower gain and vtec is always awesome to have, but if you have some kind of money to play with i would rather go with a b18 instead of b16, the b16 is just sooo weak in torgue and power on the bottom end. just my 2 cents
Re: (619_eg)
I have a b16a, and i am strictly a crx guy. But i cant find a new one, and i need a new shell ASAP. So i would pick up an EG as a temporary alternative. I dont plan on buidling a motor because "b16's aren't good for starters." My questions is more or less, is it worth putting a first gen with cable tranny into the car. Is there any problems i may run into doing this.... And i am very happy with my torqueless wonder by the way Little help from a t3/t4.
Modified by sick hatchem at 2:35 AM 11/22/2003
Re: (dantastic)
Time to piece a kit together for it.... Do you think you can pm with me with some more detials, ie. wiring, gsr hydro tranny?
Thanks
Thanks
Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">i have a b16a sir-1
-gsr tranny
-integ mounts
-obd1 everything
too slow for me</TD></TR></TABLE>
this is exactly why my b16 comes out today and ls vtec goes in today
-gsr tranny
-integ mounts
-obd1 everything
Moderator
Re: (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">a b16 is more of a track motor. track as in road racing. thats just what i think.</TD></TR></TABLE>
b16 ran a 8.6 at the strip last night....2200 lb hatch...just some info for all the b16 haters
Re: (chad)
I just dont see why you would spend an extra $1800 for 10 more hp and a bit more torque. For that price you have a quality turbo kit waiting ot be installed.
Back to topic: Is it that hard to change the car to a cable tranny?
Re: (sick hatchem)
first, i know almost nothing about the b series.....
second, is it true that an itr tranny is a b16b with a lsd and a different final?
third, is it true that an itr head is just a b16 head with some work done?
Moderator
Re: (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">first, i know almost nothing about the b series.....
third, is it true that an itr head is just a b16 head with some work done?</TD></TR></TABLE>
first.....i know alittle....not everything
second...depends on the year of the tranny....
b16b tranny is a 4.4 final drive tranny with lsd (not sure of gear ratio's)
b18c5 pre 98 tranny's are 4.4 with lsd
b18c5 after 98 are 4.785 with lsd (reason being they went with 16 rim package (this is only for JAPAN 98 or newer itr tranny's, US tranny's remained 4.4 with lsd and a closer 4th and 5th gear))
third YES a b18c5,b16b and b16a heads are from the same casting (PR3) some of the earlier C5 heads were hand ported and polished and flowed better (from the factory) but later C5 (newer) were done on the CNC or by a machine
hope that helps
hope that helps
