Oil pressure question
Old Nov 21, 2003 | 10:59 AM
RCautoworks's Avatar
Default Oil pressure question
Just a thought, When oil is cold its thicker, therefore resulting in a higher oil pressure. When it gets heated up it becomes thinner and oil pressure goes down. Well I was wondering, if I used an oil that has a higher viscosities when it warms up will my oil pressure be higher ? Just wondering, I might of got a couple things backwards but hopefully you guys get the idea.
Old Nov 21, 2003 | 12:13 PM
spaceman's Avatar
Default Re: Oil pressure question (90blackcrx)
dood your getting complicated..just get some good oils and your good to go
Old Nov 21, 2003 | 12:16 PM
Default Re: Oil pressure question (spaceman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">dood your getting complicated..just get some good oils and your good to go</TD></TR></TABLE>
I do use good oil, and I have good oil pressure, it was just a thought and was wondering if it was true.
Old Nov 21, 2003 | 02:16 PM
AzG35's Avatar
Yes, your oil pressure should increase slightly if you replace your with a higher weight oil. But higher viscosities will slow down the revving of the car depending on how high you go.
Old Nov 21, 2003 | 02:45 PM
mmuller's Avatar
Mad Scientist
Default Re: Oil pressure question (AzSi22)
too much pressure is not good, you know?
stock oil pressure is good for most applications
Old Nov 21, 2003 | 07:50 PM
magnum's Avatar
Default Re: Oil pressure question (mmuller)
Yea, stick with what Honda recomends.
Old Nov 22, 2003 | 09:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">too much pressure is not good, you know?
stock oil pressure is good for most applications</TD></TR></TABLE>
Yeah, I know, this thread was just like a curious thread. I started thinking about it and was wondering if there was any truth to it.
Old Nov 22, 2003 | 09:19 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Well I was wondering, if I used an oil that has a higher viscosities when it warms up will my oil pressure be higher </TD></TR></TABLE>
Yes, but there is no need to with an engine in good condition.
Old Nov 22, 2003 | 10:01 AM
Default Re: Oil pressure question (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, but there is no need to with an engine in good condition.</TD></TR></TABLE>
yep
bonylad
Sep 13, 2006 09:50 AM
scartail
May 12, 2005 12:09 PM
vtec.dc2
Mar 9, 2004 08:18 AM
vtec.dc2
Mar 9, 2004 04:41 AM
LSVTECoupe
Aug 30, 2003 08:52 AM
