What would be better ? EG springs with EG springs rates or DC spring rates ?
This would be for a daily driven EG, im looking for springs that would provide the most comfortable ride rather than stiffness.
Thinking about getting H&R race springs.
Do you have a swap? The teg springs will make your car sit a little higher than the civic springs.
if you are goin for comfortable ride H&R Race Springs arent for comfort ... also get them for EG ... I learned the lesson of having springs for DC and shocks for a DC2-R and now my left front sits about 1/2 higher on the left front, which is probably due to the heavier weight of a DOHC motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowboarderguy44 »</TD></TR><TR><TD CLASS="quote">if you are goin for comfortable ride H&R Race Springs arent for comfort ... </TD></TR></TABLE>
well i like my car pretty low but also comfortable, the springs will be matted up with KYB AGX's.
order ground controls, and you can order any rate you want, and can adjust them any height you want. problem solved.
EnjoyTheRideDC2
Suspension & Brakes
11
Sep 19, 2006 03:24 AM
