Individual fuzes for headlamps
Old Nov 21, 2003 | 08:17 AM
EH2_pReStO's Avatar
Default Individual fuzes for headlamps
I was wondering if any of you guys know if the low beams left and right and the high beam left and right on a EG have individual fuses for each??
The reason I am asking is that for some reason mine don't work but the bulbs are fine and the main fuse seems to be fine...
My high beams work for both..and the left low beam works...but the right doesn't...I switch the bulbs around...and still the left low beam doesn't work..
Old Nov 21, 2003 | 08:19 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: Individual fuzes for headlamps (prestoizm)
Well if the right one didn't work and then you switched them and the left one didn't, sounds like that bulb's low beam is blown.
Old Nov 21, 2003 | 08:35 AM
EH2_pReStO's Avatar
Default Re: Individual fuzes for headlamps (Mr Milano)
no i switch the bulbs..and no matter what the left low beam didn't work...the same bulb work fine on the other side...so I don't know whats up..
Old Nov 21, 2003 | 08:58 AM
93civicEX's Avatar
Yes both of your headlights and low and high beam have individual fuses, I had a problem where my left low beam didn't work but the high-beam worked fine, then i realized to look at the fuses and sure enough there was a fuse for left-high and low beam and also with right-high and low beam.
Old Nov 21, 2003 | 09:23 AM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prestoizm &raquo;</TD></TR><TR><TD CLASS="quote">no i switch the bulbs..and no matter what the left low beam didn't work...the same bulb work fine on the other side...so I don't know whats up.. </TD></TR></TABLE>
Then I suggest you read and edit your original post. There are ind. fuses. Good place to start. If not pull the plugs off the back and inspect them.
Old Nov 21, 2003 | 09:33 AM
EH2_pReStO's Avatar
Okie so thanks for the info. Now that i know that there are individual fuzes where are they located?? I checked all my fuses prior and they where fine...Are they in a different location??
I dont have a fuse cover that says what fuse is what...=/
Old Nov 21, 2003 | 10:12 AM
dwnthehatch's Avatar
Default Re: (prestoizm)
Fuse #'s 21 and 22
Old Nov 21, 2003 | 02:28 PM
EH2_pReStO's Avatar
Default Re: (dwnthehatch)
Thank you so much..this will help a lot...
Dub C
May 28, 2011 01:25 PM
Frstyl838
Lighting
Feb 9, 2009 01:07 PM
Cashieboi
12
Mar 1, 2008 08:44 PM
em2_blk_01
Honda Civic (2001 - 2005)
Sep 28, 2006 12:33 PM
