RADIATOR QUESTION NEED HELP!!
Old Nov 21, 2003 | 05:48 AM
jdkornlp's Avatar
Default RADIATOR QUESTION NEED HELP!!
I just drained my radiator fluid last night. All I did was drain it from the drain bolt. I didnt bleed it because there isn't a bleeder valve on the 99 si b16 motor. So, today i squeezed the hoses for like an hour with the cap off to release any air bubbles that could have been in there. Still, I have no radiator fan and my car overheats in 5 minutes when driving. What could the problem be and how can i fix it??
Old Nov 21, 2003 | 07:04 AM
Rtype16's Avatar
Default Re: RADIATOR QUESTION NEED HELP!! (jdkornlp)
where you squeezing the hoses with the motor running?
jdkornlp's Avatar
Default Re: RADIATOR QUESTION NEED HELP!! (Rtype16)
the top and bottom radiator hoses.
Old Nov 21, 2003 | 07:29 AM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdkornlp &raquo;</TD></TR><TR><TD CLASS="quote">Still, I have no radiator fan and my car overheats in 5 minutes when driving.</TD></TR></TABLE>
Do you mean your rad fan does not kick on at all ? Or you just don't have one ? If it don't kick on its either a fuse or the sensor. Or your fan could be bad, but I would put my money on the sensor or fuse first.
Old Nov 21, 2003 | 07:38 AM
jdkornlp's Avatar
Default Re: RADIATOR QUESTION NEED HELP!! (90blackcrx)
fuse is fine, i have a fan, and as of now i jump it to get it working so the motor is good to.
Old Nov 21, 2003 | 07:45 AM
Ok so then its a wiring issue some where, more the likely its the sensor for the fan.
Old Nov 21, 2003 | 02:51 PM
jdkornlp's Avatar
Is the fan my only problem? Shouldn't the engine temp be able to stay down for a little more than 5 minutes without the radiator fan?
Old Nov 22, 2003 | 03:51 PM
Maybe your water pump is not working, or you have a clog some where.
Old Nov 24, 2003 | 04:57 AM
JimBlake's Avatar
Sounds like you might have a bad fan switch, but that's not the only problem...
When you say it overheats while 'driving', are you stuck in traffic, or driving at 40mph or more? If you're actually moving the whole time, you don't even need the fan. Driving at 30 or 40 pushes more air thru the radiator than the fan, anyway.
If it overheats while you're actually driving 40 or more, then it's a bad thermostat, radiator, waterpump, or something UNRELATED to the fan.
pyrojeff
Oct 21, 2019 09:50 AM
Maxpower350
Jul 16, 2006 06:56 PM
adobospoon
Jun 12, 2005 07:29 PM
adnohr
May 31, 2005 10:10 AM
