Does Dent King work?
Old Nov 20, 2003 | 10:49 PM
WhoisDan's Avatar
Default Does Dent King work?
They sell the Dent King at Kragens, etc. I think it was also advertised on TV. My friend has it and he hasn't used it. He got the thing for free, so it is just sitting around. Has anyone tried using it? Does it actually work? Does it make the body/dent worst?
Old Nov 20, 2003 | 11:01 PM
Downey's Avatar
Default Re: Does Dent King work? (whoisdan)
yes it does. took out some major dents on my bros car!
Old Nov 20, 2003 | 11:33 PM
WhoisDan's Avatar
Default Re: Does Dent King work? (Downey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downey &raquo;</TD></TR><TR><TD CLASS="quote">yes it does. took out some major dents on my bros car! </TD></TR></TABLE>
Sounds good.
Old Nov 21, 2003 | 04:06 AM
Stewie's Avatar
You should of serched first. I had the same question and the older threads were much help.
Old Nov 21, 2003 | 11:12 AM
WhoisDan's Avatar
Default Re: Does Dent King work? (Mac8008)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mac8008 &raquo;</TD></TR><TR><TD CLASS="quote">You should of serched first. I had the same question and the older threads were much help.</TD></TR></TABLE>
I typed in "Dent King" but no results showed up.
Old Nov 21, 2003 | 11:15 AM
fivespeedintegra's Avatar
try "ding king"
and i'm not sure how well it works, but they glue they give you is hard to get off from what i've read.
Old Nov 21, 2003 | 11:51 AM
IntEGNYC's Avatar
Default Re: (fivespeedintegra)
i used ding king to remove all of my minor parking lot dents. Damn mall grannys!
patience and knowing which angle to pull will help immensely.
Old Nov 21, 2003 | 11:53 AM
Default Re: (IntEGNYC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">i used ding king to remove all of my minor parking lot dents. Damn mall grannys!
patience and knowing which angle to pull will help immensely.</TD></TR></TABLE>
like door dings and stuff? cause i have a few of those that i'd love to get rid of...
Old Nov 21, 2003 | 01:35 PM
95integrags-r's Avatar
I tihnk you have to make sure how you pull the dent out is correct. cause my friend tried it with his GTI and it pulled the dent out, but made a differentdent that he cant get out because of it. maybe he is just an idiot though
Old Nov 21, 2003 | 10:12 PM
IntEGNYC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fivespeedintegra &raquo;</TD></TR><TR><TD CLASS="quote">
like door dings and stuff? cause i have a few of those that i'd love to get rid of...</TD></TR></TABLE>
yep. mall granny kick their doors out, and ask questions later. had them in the doors and quarter panels. also had some small dents in the fenders (probably from their shopping carts)
I suggest being very careful. the sheetmetal in integras are soft and pliable. I had only minor success wiht my maxima which has harder sheetmetal. patience
the worst that can happen is you pull a peak out of the metal and have the dent convexed rather than concave. hehe
Old Nov 21, 2003 | 10:53 PM
integraL's Avatar
i wanna try this. i have one little dent on my passenger side door. do you suggest i try this integnyc?
Old Nov 22, 2003 | 05:12 AM
the worst that can happen is you pull a peak out of the metal and have the dent convexed rather than concave. hehe</TD></TR></TABLE>
yeah i know how soft the sheetmetal is ....so if i pull it slightly concave.....i can push it back down, maybe?
Old Nov 22, 2003 | 05:23 AM
Jay J's Avatar
Prince of Zamunda
Well use dry ice for door dings... Using this dent king will risk the clear coat peeling off.
Old Nov 22, 2003 | 09:57 AM
WhoisDan's Avatar
Default Re: (neuspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neuspeed &raquo;</TD></TR><TR><TD CLASS="quote">Well use dry ice for door dings... Using this dent king will risk the clear coat peeling off. </TD></TR></TABLE>
I heard about the dent king ripping off clear coats. How do you use dry ice?
Old Nov 22, 2003 | 10:03 AM
n0 iNTegRiTY's Avatar
I used it on my step-dad's Alero. Basically, put it on, let it sit, pull off, and repeat about 50 times or until satisfied. It didn't completely get rid of the dent, but it did decrease the size a lot. And I'm assuming where the ding is on the car also plays a factor on how easily it will come out.
Old Nov 22, 2003 | 12:10 PM
Jay J's Avatar
Prince of Zamunda
Default Re: (whoisdan)
for dry ice you put it on the other side of the dent if possible and take a hair drier and heat it or if not put the dry ice on the edge of the dent and heat it...
RS2 FAB
Welding / Fabrication
Feb 10, 2008 12:28 PM
globlctzn
Honda Motorcycles
19
Mar 13, 2005 10:49 PM
evilm
Nov 13, 2003 10:18 AM
drevinder
Aug 12, 2003 09:46 PM
