Need help installing hondata s200 to a p75 ASAP!
Old Nov 20, 2003 | 09:54 PM
roydogg's Avatar
Default Need help installing hondata s200 to a p75 ASAP!
Okay I need help installing this s200 system. I understand where to soder the 28 pin, 74hc373, and the cn2 1-4. Now what do I do with the 2 medal wicks and the 2 blue and clear plastic things?
What else has to be done in order for this to work?
I downloaded the manual but the instructions just aren't to clear for me to understand.
I'm sorry for the noob question but I would really appreciate if someone could help me ASAP.
Thanks,
Roy
Modified by roydogg at 9:54 AM 11/21/2003
Old Nov 21, 2003 | 05:55 AM
roydogg's Avatar
Default Re: Need help installing hondata s200 to a p75 ASAP! (roydogg)
Help someone!!
Old Nov 21, 2003 | 06:04 AM
racerxadam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roydogg &raquo;</TD></TR><TR><TD CLASS="quote"> Now what do I do with the 2 medal wicks and the 2 blue and clear plastic things?</TD></TR></TABLE>
what is a medal wick? If you follow the instructions word for word from the installation manual it will work. I believe the "blue plastic things" are wire connectors to tap into the check engine light circuit for the shift light.
Old Nov 21, 2003 | 06:14 AM
roydogg's Avatar
Default Re: Need help installing hondata s200 to a p75 ASAP! (racerxadam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racerxadam &raquo;</TD></TR><TR><TD CLASS="quote">
what is a medal wick? If you follow the instructions word for word from the installation manual it will work. I believe the "blue plastic things" are wire connectors to tap into the check engine light circuit for the shift light. </TD></TR></TABLE>
Thanks Adam!! Can someone confirm this? So I don't have to worry bout the plastic things then huh?
So what does the instructions mean by solder in J1 and cut J12?
Old Nov 21, 2003 | 06:26 AM
racerxadam's Avatar
If you look on the green board that everything is soldered to you will see things that are labled. J1 is a location on the board, if you orient the ecu like it is in the installation manual it is just above the location for the 28 pin rom socket. You have to desolder the holes and then solder a wire into the two holes. You have to do the same in the R54 location which is right next to the J1, except in R54 you have to solder a 1.1Kohm resistor.
Old Nov 21, 2003 | 08:23 AM
PHiZ's Avatar
I'd consider having a professional do it, you can very easily **** up the ecu and have to buy a new one.
-PHiZ
Old Nov 21, 2003 | 08:51 AM
roydogg's Avatar
Default Re: Need help installing hondata s200 to a p75 ASAP! (PHiZ)
I'm backing out and gonna sell it. I'm thinkin bout going with the Safc for the time being. I'm basicly pulling out on this s200 install .
Old Nov 21, 2003 | 08:54 AM
HXMan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roydogg &raquo;</TD></TR><TR><TD CLASS="quote">I'm backing out and gonna sell it. I'm thinkin bout going with the Safc for the time being. I'm basicly pulling out on this s200 install .</TD></TR></TABLE>
Man, just spend $50 to get it done professionally. You already have all the stuff you need, why go and buy a SAFC now? You will be much happier with hondata
Old Nov 21, 2003 | 09:54 AM
DC2R714's Avatar
Default Re: Need help installing hondata s200 to a p75 ASAP! (HXMan)
PM 93lsivic he can do it for you. He is close to you.
Old Nov 21, 2003 | 11:06 AM
roydogg's Avatar
Default Re: Need help installing hondata s200 to a p75 ASAP! (DC2R714)
I meeting up with Adam soon have him do it. I hope I get done for tomorrows dyno .
Cuban/jdm ricer
Engine Management and Tuning
Jan 11, 2013 11:40 AM
Losrocket_
Apr 24, 2005 05:43 PM
EP3vudu
Jun 15, 2003 01:54 PM
