air con on an 95 Eg hatch
ok did a search on the air con's making funny noises, and i think its got to the with the a/c compressor clutch
so is this part of teh car replaceable and doees anyone know how much it is second hand?
and the next thing i want to ask is when the car is idle and the compressor is engaged after awhile the car would start blowing warm air. Is there a reason behind this?
but when the car starts crusing again a/c goes back cold? this one has left me alittle more mystified.
Cheers for the help
Cheers for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG4 »</TD></TR><TR><TD CLASS="quote">
Is the condensor fan working?
Sounds like you need freon....a 95 should use R134a... Walmart has it...
If you need a comp. go here: http://www.car-part.com/
what's a freon?
oh it was the air condensor fan not working, only thing i have no idea how to get to working now??
looks like its notgetting any power at the moment, looks like the relays could be gone
and the shuddering occered coz i had excess gas, not exactly sure how that happens?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG4 »</TD></TR><TR><TD CLASS="quote">what's a freon?
and the shuddering occered coz i had excess gas, not exactly sure how that happens?</TD></TR></TABLE>
Get the fan working and the other problems will probably go away also. Have you checked the fuses? Have you checked for power and ground at the fan?
