94 del sol.....Rear Disk Brakes???
Old Nov 20, 2003 | 09:05 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
Default 94 del sol.....Rear Disk Brakes???
Do they have?? I dont know......help me out....
Old Nov 20, 2003 | 09:07 PM
lost_sol's Avatar
Default Re: 94 del sol.....Rear Disk Brakes??? (dgonzals)
yes they got em
Old Nov 20, 2003 | 09:09 PM
dgonzals's Avatar
thanks bro.....do they si sols have them? no matter what the year
Old Nov 20, 2003 | 09:14 PM
phantom_sol's Avatar
Default Re: (dgonzals)
93-97
del sol s = no
del sol si = yes
94-97
del sol vtec = yes
vtec has 10.2" inch front rotors as opposed to the 9.5" s/si
Old Nov 20, 2003 | 10:13 PM
clm's Avatar
clm
Default Re: (phantom_sol)
93-95 S - no
93-95 Si - no
96-97 S - no
96-97 Si - yes
93-97 VTEC - yes.
Old Nov 20, 2003 | 10:19 PM
locass316's Avatar
Default Re: (clm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clm &raquo;</TD></TR><TR><TD CLASS="quote">93-95 S - no
93-95 Si - no
96-97 S - no
96-97 Si - yes
93-97 VTEC - yes.</TD></TR></TABLE>
93-95 si do have them
sol2nr's Avatar
Default Re: (clm)
93-95 Si - no
96-97 S - no
96-97 Si - yes
that is wrong...... i have a 93 del sol Si and it HAS rear disk brakes.
EDIT: i'll keep it up for verification, but i posted the exact same time as the previous post...not repeating stuff for now reason.
Old Nov 20, 2003 | 10:38 PM
clm's Avatar
clm
Default Re: (sol2nr)
Hmm... I don't ever recall seeing them as an option. Learned something new.
And I also put down '93-'97 VTEC.
Old Nov 20, 2003 | 10:52 PM
according to my 1993 honda del sol service manual, si's of that year were the only del sol to have rear disks. after 93, it was the del sol si and vtec. but del sol s was to cheap and had drums throughout its production.
the only difference between the brake setup of a del sol vtec and si are the front brakes and master cylinder. the del sol vtec (b16) uses the same 10.2" front brakes found on Integras (dc; 94+) and Civic Si's (ek; 99-00)
the del sol si shared the same 9.5" front disk as the del sol s.
trust me, i swapped my brakes to integras already same spec as del sol vtec but instead of using a 7/8" master cylinder, i used the jdm integra type-r 15/16" non abs mc.
Old Nov 21, 2003 | 08:27 AM
dohcdelsol's Avatar
95 delsol si has rear disc brakes. Come to think about it, mine are shot. Guess i have some work to do this weekend.
Old Nov 21, 2003 | 01:32 PM
del type-r's Avatar
[QUOTE=phantom_sol] trust me, i swapped my brakes to integras already QUOTE]
Put interga rear trailing arms on mine too.. matches right up. The only problem i found was that the teg e-brake cable is a little too long, but they way i put mine on it works fine.
Old Nov 21, 2003 | 04:43 PM
Default Re: (del type-r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del type-r &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=phantom_sol] trust me, i swapped my brakes to integras already QUOTE]
Put interga rear trailing arms on mine too.. matches right up. The only problem i found was that the teg e-brake cable is a little too long, but they way i put mine on it works fine.</TD></TR></TABLE>
exactly, though i swapped my with my friends rear disk conversion. ironically he had del sol vtec rear brake assembly and i had integras. the integras worked perfectly in his ek coupe, while he traded me for them for the del sol rear e brake lines. but as far as the question. all si del sols and vtec del sols have rear disks.
89civicb16a1
May 20, 2006 09:50 PM
i be wood
Dec 29, 2004 07:56 PM
71 mgb
Oct 5, 2003 03:31 PM
EODsol
May 20, 2003 05:36 PM
