wuts this?
wuts this?
hey guys im sure that a lot of you probally think this is a dumb question but i have never seen anything like this and i was wondering what it is called, what it does, and its benefits if any... i know on my car i have a compressoin hose that goes from there to my intake ... tia
Re: wuts this? (uranazo)
Its a breather that replaces the oil breather line. The line runs to intake pipe and dumps excess oil. You can also connect an oil catch can to it.
Re: wuts this? (txhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by txhatch »</TD></TR><TR><TD CLASS="quote">Its a breather that replaces the oil breather line. The line runs to intake pipe and dumps excess oil. You can also connect an oil catch can to it.</TD></TR></TABLE>
Do you usually dump excess oil into your intake?
Re: wuts this? (I Hate Steve!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Hate Steve! »</TD></TR><TR><TD CLASS="quote">It release excess pressure off the head...I prefer a hose on mine. If you use the hose you plug it into the intake system anywhere after the filter(i.e. intake/intake manifold). I'm not completely sure but I think the filters/breathers are more for looks.</TD></TR></TABLE>
First off it is smog equipment....the hose anyway.
Its to compensate for exsessive pressure under your valve cover in the head.
The hose keeps the Oil vapor from going out into the open air and polluting the atmosphere.
The breather keeps the Oil vapor from entering your intake and taking away performance.
The oil vapor takes up space when entering the combustion chamber....space that we would prefer to be occupied by air and fuel.
Re: (uranazo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uranazo »</TD></TR><TR><TD CLASS="quote">so they just release oil pressure correct? are they cheap/easy to get? is it worth the money?</TD></TR></TABLE>
No.
All these dam noobs are ruining the rep of honda-tech.
If you look at a stock intake, you'll see that there is a pipe comming out of the valve cover and going into the intake pipe.
After gettting after market intake, some people keep the pipe some people put breather there. your prefference.
It's main purpose is not to release the oil.
Your engine is desinged to suck in air, and all the excessive air which the engine doesn't need, the engine puts it back into the intake pipe.
People put breather there, so that air can just release out.
No.
Re: (uranazo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uranazo »</TD></TR><TR><TD CLASS="quote">sorry for tryin to learn, next time ill just stay stupid... </TD></TR></TABLE>
Don't let them get to you, you never know what kind of **** anyone is dealing with on the other end....sometimes people are just in a pissy mood.
H-T is high school, you gotta ignore the rude and idiotic.
Re: (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">
dawn right !!
dawn right !!
Re: (oddball327)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oddball327 »</TD></TR><TR><TD CLASS="quote">i dont have anything connected.. doesnt matter</TD></TR></TABLE>
YEs that does...you have an opening into your valve cover and crap gets sucked into your oil! ITS VERY BAD!!!
Re: (jDmDxTuRd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDmDxTuRd »</TD></TR><TR><TD CLASS="quote">Filters on your crank case vent are stupid. Put the damn hose back on. </TD></TR></TABLE>
<---has a hose and still can't pass smog cause it is a "heater" hose and not a "PCV" hose!
Re: (sshaikh01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sshaikh01 »</TD></TR><TR><TD CLASS="quote">
No.
People put breather there, so that air can just release out.</TD></TR></TABLE>
LOL, at the beggining of your post I thought you were going to set everyone straight. Oh well, i'll do it.
The purpose of the breather pipe/filter is to allow clean filtered air into the engine so that the PCV system works properly. When the PCV valve opens air goes into the engine through the breather pipe.
No.
Re: (Chiovnidca)
To add one more informative post to this topic which has been led astray:
The filter is there for one thing: looks
Hose: recycles air back into the head
Filter: same thing as without anything, but allows pressure release without anything getting back into your motor
Yes & No's
Yes it is the same as having a hose
No it will not affect hp's if you switch
Yes it is a good idea to have one or the other
AND Finally: No it is not wise to buy this for the simply fact that teh filter can get clogged, leaving you with pressure build up, which inturn could blow seals
Yes & No's
Re: (Night_Ryder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Night_Ryder »</TD></TR><TR><TD CLASS="quote">breather helps a lil </TD></TR></TABLE>
actually it serves the same purpose as the hose.......read above post^
Re: wuts this? (Kikomon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kikomon »</TD></TR><TR><TD CLASS="quote">
There, it look like me but alot smaller....I shall call you MINI ME!!
Re: (uranazo)
Looks better than the hose. And $10 for an OBX filter at any performacne shop.
~: DROOLING :~ Over the Drag Turbo Kit for D Series!
Raocorp
10
04-27-2003 02:22 AM
