help...my speed tach don't work.
Old Nov 20, 2003 | 07:33 PM
methos713's Avatar
Default help...my speed tach don't work.
okay...when i had my b16 motor in my car, the speed tach worked, but after i changed tranny, the speed tach didn't work....the needle would go up and then down. Now after swapping in my o.g. motor...the tach still didn't work. I don't feel my vtec kick in...Help and Info would be greatly appreciated. By the way, at first i thought it was the vss, but now i don't know. Thanks.
Old Nov 20, 2003 | 07:46 PM
boondockgtr's Avatar
Default Re: help...my speed tach don't work. (methos713)
not to be a dick or anything, but its called a speedometer.
Old Nov 21, 2003 | 05:20 AM
Mikey3000's Avatar
it probably is your VSS. i believe the VSS is one parameter that must be functional for vtec to work too.
Old Nov 21, 2003 | 08:58 AM
mmuller's Avatar
Mad Scientist
Default Re: help...my speed tach don't work. (Incognito H22A)
did you put the old vss in the new tranny? did you reconnect it?
Old Nov 21, 2003 | 09:17 AM
methos713's Avatar
Default Re: help...my speed tach don't work. (mmuller)
when i did my swap, i had a gsr tranny with a vss already, and it working properly at first...until later when we changed the clutch. As for my single vtec, which is in my car right now....i never changed the vss...it's orginal. I thought that maybe it could be the wires or the plug that connects to the vss or something else. Well any more INFO would be great. And thanks for the feedback guys.
Old Nov 21, 2003 | 09:30 AM
dohcnotec's Avatar
I had same problem once and changed out 3 different vss. I ended up having a fuse blown. I think it was #14 in a 2000 Civic. Does your battery light come on with the ignition on/engine off? If not, that's ur problem.
Old Nov 21, 2003 | 09:45 AM
crxtreme89h's Avatar
Default Re: help...my speed tach don't work. (dohcnotec)
Did you plug the Cable into the new Tranny and put the C clip back on it.
Old Nov 21, 2003 | 09:57 AM
dohcnotec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 &raquo;</TD></TR><TR><TD CLASS="quote"> Now after swapping in my o.g. motor...the tach still didn't work. I don't feel my vtec kick in....</TD></TR></TABLE>
I believe his "o.g." motor means stock and vtec didn't come stock till 92+ meaning no speedo cable
Old Nov 22, 2003 | 08:07 AM
methos713's Avatar
i have a 95 civic si hatch...the stock motor is back in, as for the fuse, i'll check that out...to see if that is the problem. If not, i might just go get myself a vss...anyone know how much it is? Thanks.
MIEj1
May 15, 2012 02:39 PM
watacanga
Nov 29, 2007 08:47 AM
Delano5050
May 5, 2007 08:52 AM
stealth89hatch
13
Jun 17, 2005 03:25 PM
lowcivex
Apr 13, 2003 10:57 AM
