DOHC ZC Oil Pan
It appears as though my oil pan on my DOHC ZC has been over-torqued and is now very slowly leaking oil. Do any ZC owners know what kind of replacement oil pan would fit the ZC? Also, because I am extremely poor at this time, does anyone have a good temporary solution to my dilemna? Can I re-tap my oil pan and just use a larger screw? Help me out fellas, btw, I already tried to search. Thanks
The d16a6 pan will work for sure. As for what you can do right now, grab some Hondabond or Permatex Ultra Grey and put a thin layer of that around the gasket and hope it seals. It has to set for a day or 2 to fully cure.
The D16a6 pan will only work if you dont have the DOHC ZC header. Because the ZC pan ha more clerance for the DOHC ZC header. Use the integra 88-89 oil pan
2stockrocketz
May 8, 2004 01:32 PM
iplaybass
Jan 22, 2004 09:14 PM
