obd1 h22 in 96 accord help ?
urg wont run with the h22 obd1 ecu , but will with the accord ecu , im using a jdmhondaparts jumper.
Modified by racerboyb18c1 at 8:20 AM 11/21/2003
Modified by racerboyb18c1 at 6:53 PM 11/21/2003
its a obd1 motor in a 96 obd2 car, the wires were redone to make the distributer work also it runs fune with the accord ecu perfect in fact, i purchased an obd1 conversion harness from jdm honda parts and it will not run with the obd1 h22 ecu it barely idles then if you touch the gas it dies .
Any codes?
I've used a JDM P13 Auto ECU in a OBD-2 Accord H22 swap before and it ran....but with a flucuating idle that I never got around to figuring out before the owner threw a rod in it.
still not working
