(tachnometer problem) Autometer Tach needle jumps past 10K Please Help
Old Nov 20, 2003 | 01:19 PM
DelsolVtec18's Avatar
New User
Default (tachometer problem) Autometer Tach needle jumps past 10K Please Help
I have a autometer tac hooked up to a msd in a delsol with b18c. The needle jumps past 10k and stays there when i turn the ignition key on. It stays there then when i start my car and then just drive, it starts coming back down to normal. This happens out of no where and seem to do this time to time. What might cause this and how can I fix this? Thanks...
Old Nov 20, 2003 | 04:30 PM
New User
Default Re: (tachometer problem) Autometer Tach needle jumps past 10K Please Help (DelsolVtec18)
update: The needle on the tach doesn't come back down right after i start the car. It comes back down like 5min, 10min, 30min, or just whenever time it feels like it, and sometimes dont even come back down and just stays past 10k. And sometimes when im driving the tach needle would jump back past 10k out of no where for no reason. Please help...
Old Nov 20, 2003 | 05:16 PM
tfalconier's Avatar
sounds like u have a bad ground somewheres
Old Nov 20, 2003 | 06:03 PM
New User
Default Re: (tachometer problem) Autometer Tach needle jumps past 10K Please Help (tfalconier)
I will try grounding the wire somewhere else...
Anybody else have any other suggestions or have this happened to anyone else...
Thanks...
Old Nov 21, 2003 | 12:47 AM
New User
bump for night
Old Nov 21, 2003 | 05:18 AM
Mikey3000's Avatar
is it a new tach? those autometer gauges break pretty easily if you touch the sender wire to something you're not supposed to touch it to, like a hot wire.
Old Nov 21, 2003 | 07:21 AM
New User
Default Re: (tachometer problem) Autometer Tach needle jumps past 10K Please Help (Incognito H22A)
Brand new tach from autometer. I dont think i touched any other wire. Just installed it following the instructions.
Old Nov 21, 2003 | 09:05 PM
New User
ttt
Old Nov 22, 2003 | 02:52 AM
omega11855's Avatar
if you have a short in the rpm wire it would do that
CimorelliCRX
14
Jul 2, 2005 02:25 PM
01_S2k_Driver
Feb 15, 2005 07:49 PM
94hondaLS
Jun 23, 2003 10:28 PM
grlstockb18c1
Jun 20, 2003 09:11 AM
