obd1 h22 in 96 accord help wiring?
Old Nov 20, 2003 | 01:06 PM
racerboyb18c1's Avatar
Default obd1 h22 in 96 accord help wiring?
runs with the f22 ecu but not with the obd1 conversion harness and h22 p13 , no codes , whats the diff wiring if ne ? please help really need soon , also it does run but not well with the h22 ecu ...
Old Nov 20, 2003 | 03:38 PM
Default Re: obd1 h22 in 96 accord help wiring? (racerboyb18c1)
bump please?
Old Nov 20, 2003 | 03:47 PM
KTeller8's Avatar
what is the problem?
If you use the obd2-1 harness you have to make sure they switched the two pins in the harness, accord is the only car in the honda world that has the egr and temp pins switched..
it should run better with the p13 h22 ecu, the f22 one is crap and will make the h22 run all nasty when its all said and done
Old Nov 20, 2003 | 04:24 PM
v4lu3s's Avatar
RTFM
you may need to get a wiring diagram out for the obd2 pinouts and compare that the obd1 pinouts and check the harness.
Old Nov 20, 2003 | 08:59 PM
Default Re: (v4lu3s)
ok i cant find ne where the hosts a obd2 pinout for the accord
Old Nov 21, 2003 | 09:51 AM
Default Re: (racerboyb18c1)
bump
petrojdmcd5
Apr 5, 2006 10:25 PM
zoomspeed05
Feb 19, 2006 11:04 PM
Accord_Kid
Apr 19, 2005 05:28 PM
CivicFerioSiR
Sep 4, 2004 07:43 AM
racerboyb18c1
Dec 1, 2003 06:34 PM
