leaking tranny oil pretty bad...new shift shaft seal? from what car tho?
Old Nov 20, 2003 | 12:43 PM
Project_ED8's Avatar
Default leaking tranny oil pretty bad...new shift shaft seal? from what car tho?
i was wondering....i have a 88 hf crx with a 94-95 B16A3 motor in it. do i get a shifter shaft seal from a del sol or a 90-91 integra since i use integra axles and mid shaft right? or is it only the jdm b16's you use integra axles? i'm pretty sure its any b16 you use integ axles right? also....i've searched around...and it seems to me that there is only one seal where the shift linkage meets the tranny(shifter shaft seal) but why is there two parts to my shift linkage...both going to my tranny? cause i remember on my D16A6 motor...there was only one bar going to the tranny for the shift linkage i think...but now there is two? does anyone know what that other seal is called? well thanks for any help.
Old Nov 20, 2003 | 12:49 PM
Default Re: leaking tranny oil pretty bad...new shift shaft seal? from what car tho? (Project_ED8)
also...for the axle seals...where both axles meet the tranny. do i use del sol axle seals? or integra? and from what year? ok thanks for the help
dopehouse
Transmission & Drivetrain
Oct 26, 2011 09:51 PM
ScoobCivic
Jun 10, 2004 09:21 AM
Ransom
Apr 8, 2004 02:27 PM
lillex
Dec 4, 2003 04:17 AM
JoshM
Feb 5, 2002 04:44 AM
