rear wheel bearing??
Old Nov 20, 2003 | 10:59 AM
Audipwr1's Avatar
Default rear wheel bearing??
right rear wheel area is making a squeeking noise when traveling. I assume it to be the wheel bearing. What can i do to test if this is the case, and how long can i expect it to be safe to drive on?
Old Nov 20, 2003 | 11:15 AM
96-EJ6 B18C's Avatar
Default Re: rear wheel bearing?? (Audipwr1)
Jack your car up and try to wiggle the wheel toward and away from the car. If it moves, the bearing is shot...get a new one asap.
Old Nov 20, 2003 | 12:19 PM
Audipwr1's Avatar
Default Re: rear wheel bearing?? (96-EJ6 B18C)
thanks
Old Nov 20, 2003 | 03:13 PM
tilt's Avatar
if you end up needing one, i have a new rear hub/bearing for the gsr.
Old Nov 22, 2003 | 02:02 PM
rob d's Avatar
Default Re: rear wheel bearing?? (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">if you end up needing one, i have a new rear hub/bearing for the gsr. </TD></TR></TABLE>
how much?
Old Nov 22, 2003 | 02:25 PM
tilt's Avatar
Default Re: rear wheel bearing?? (rob d)
http://www.acuraautomotivepart...y.jsp
acuraautomotive has it listed for 147.38
I'll sell you the same part for 120 shipped. thats over 30$ cheaper if you factor in shipping.
lowtegsr
Jan 31, 2008 04:30 PM
vtfootball54
Jan 22, 2007 04:32 AM
BrandonClaps
Jun 20, 2003 11:20 PM
