Hid in a dc questions.
Old Nov 20, 2003 | 10:24 AM
97itr86's Avatar
Default Hid in a dc questions.
A friend of mine just put the Cl bulbs and ballast in his teg but they are pointing off to the sides. Should he take apart the projector and remove the little black peice inside of it. Any help please.
Old Nov 20, 2003 | 10:29 AM
LODOSS's Avatar
Default Re: Hid in a dc questions. (97itr86)
did he have to mofidy the bulbs to get them to fit in there? if he did then most likely they are not positioned properly.
Old Nov 20, 2003 | 10:39 AM
97itr86's Avatar
Default Re: Hid in a dc questions. (LODOSS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LODOSS &raquo;</TD></TR><TR><TD CLASS="quote">did he have to mofidy the bulbs to get them to fit in there? if he did then most likely they are not positioned properly. </TD></TR></TABLE>
I don't remember any mods being done really to make them fit. We have adjusted every screw and turned the bulb every direction but it just isn't working right.
Old Nov 20, 2003 | 12:36 PM
Slain's Avatar
cl uses a d2r capsule ( reflector style headlight ) you need to find a d2s capsule ( projector headlight) ...on the d2r there is a black band around the top of the capsule to restrict light from hitting certain areas. a d2s doesnt have that band.
Old Nov 20, 2003 | 12:53 PM
97itr86's Avatar
Default Re: (Slain)
But is the band removable because I can see a black thing running across the top.
Old Nov 20, 2003 | 10:32 PM
Slain's Avatar
i've heard of people shaving this band off.... you may have to do some searching on it but i know its been done. i've seen d2s capsules on ebay go for under 85 dollars for the pair.
Old Nov 20, 2003 | 11:40 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (Slain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain &raquo;</TD></TR><TR><TD CLASS="quote">i've heard of people shaving this band off.... you may have to do some searching on it but i know its been done. i've seen d2s capsules on ebay go for under 85 dollars for the pair. </TD></TR></TABLE>
I saw one auction that had 12 brand new Phillips 4300K D2S bulbs for $32 each.
Old Nov 21, 2003 | 12:08 AM
Slain's Avatar
hot damn 32 bucks i might just stock up
Old Apr 25, 2004 | 08:06 PM
JBBNJ609's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
I saw one auction that had 12 brand new Phillips 4300K D2S bulbs for $32 each.</TD></TR></TABLE>
but here is the question will those bulbs work in an oem kit . . i have an oem d2r kit and have the same problems as this guys friend . . i may try and shave the things but i would rather just buy a set of bulbs . . .
standbackimapro
Nov 30, 2007 05:46 AM
eg:R
17
Jan 22, 2007 04:49 PM
Hella Clean
Jul 15, 2002 06:28 AM
SonicGSR
Feb 6, 2002 08:47 PM
FusionITR
Dec 5, 2001 11:57 PM
