Timeslip...did I hit 13's?
hmmm
tires psi was around 20
i launched about 4 pretty much dumped the clutch, little spin when the nitrous kicked in but not much
the nitrous just activates at WOT
its alot harder to launch running nitrous than I expected...even with the drag radials...tires like to spin big time
traction is my biggest problem with the zex kit. I'm running a 14.4 on the stock gsr tires ( god i hate xgt-v4's!), tire spin is a bitch... i usually feather the clutch a little and make sure not to hit wot till i got traction... but i'm still new to the track and my reaction times suck!
Fix that reaction time and you'll be runnig 13.5-13.6
Good run
Good run
hehe you just barely got into the 13's. With slicks you'd probably hit a 13.7 at best providinig you get a 1.9 60'
nice, congrats, by the way couldnt u technically not arm the zex kit with the swicth till after u launch then flip the switch and let it spray at wot? or i am confused about the way the zex kit works??
2. spraying off the line will produce a better 60 ft than I could manage w/out spraying
and .500 is the best reaction you can get, not that it mattered on this run cause I was racing a sport bike
needless to say he won
Buy an LS...
heh heh
That's because yer GS-R is slow.
Buy an LS...
heh heh
Buy an LS...
heh heh
The Nitrous will help you most in the 60', very important.... too much wheel spin will only get you higher 1/4 end speed tho....ummmm get better tires for the track ?! Or try launching at a lower rpm to get initial traction and then juice it....
The power of the purple bottle...... Nice times but you should be in the mid 13's with a little more practice.
EVIL
EVIL
Seriously the only reason he ran 13's is:
I installed the kit.
Also, wasn't it was 32 Deg F when he ran?
LOL Type C you got me ROFL.
How is the wrx treating you? Boost that thing like no tomorrow.
EVIL
EVIL
