Any pics of Koni yellows? on 16' rims pls..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm 98spec R »</TD></TR><TR><TD CLASS="quote">Has anybody have a pic of an itr with koni yellows?? with 16' rims pls..</TD></TR></TABLE>
How do you put shocks "on" rims?
Even then it would sepend on the springs used in conjunction with the shocks ... if you're actually looking for a pic of "wheel" gap ....
There ya go...my setup is GC coilovers (400F/350R) w/Koni Yellows including rear externally adjustables.
In all honesty I would go w/a 15x7 wheel 16" is too big IMO.
These wheels are actually off my Prelude, they are 215/45/16. I was test fitting these in the pic and actually had some rubbing issues.
Also 15" tires are much cheaper than 16...something to consider.
What Jdm 98 SpecR meant was,
Koni Yellows with stock springs on the lower perches with 16" wheels pls.
As we are contemplating wether it would give our rides a good lowering or not.....
Thanking you,
Thanking you,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteec »</TD></TR><TR><TD CLASS="quote">What Jdm 98 SpecR meant was,
Thanking you,
My koni's are on the middle perch.
Are you thinking of just running the Koni's w/the stock springs? If so my car does not represent that, it is lowered on Ground Control Coilovers.
I would just purchase the Ground Controls as well, then you can *adjust* to any height you wish.
Thanking you,
whttyper1998
Jan 20, 2002 07:00 PM
