Toda clutch kit problem
Old Nov 20, 2003 | 06:51 AM
paulITR's Avatar
Default Toda clutch kit problem
I switched from stock to Toda clutch kit and when I release the pedal for the first part clutch doesn't engage and start to grab only in the last top 2 inch part.
So I have half stroke of the pedal that is useless and believe me is very annoying.
Is there anyone that could tell how to solve the problem ?
Old Nov 20, 2003 | 09:11 AM
Bbasso's Avatar
Default Re: Toda clutch kit problem (paulITR)
Maybe rebleed it?
Old Nov 20, 2003 | 09:30 AM
98cwitr's Avatar
take it to a stealership and get it adjusted
Old Nov 20, 2003 | 10:05 AM
Black R's Avatar
25 Year Member
https://honda-tech.com/zerothread?id=667144
-hth
Old Nov 20, 2003 | 10:43 AM
paulITR's Avatar
Default Re: Toda clutch kit problem (Black R)
Thanks Black R
Old Nov 20, 2003 | 12:38 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulITR &raquo;</TD></TR><TR><TD CLASS="quote">I switched from stock to Toda clutch kit and when I release the pedal for the first part clutch doesn't engage and start to grab only in the last top 2 inch part.</TD></TR></TABLE>
DO NOT PUT THE CLUTCH IN ALL THE WAY WITH THE CAR RUNNING! ADJUST IT ASAP! if you push the clutch in all the way, the pressure plate fingers will rub the disc. it's a good clutch, but you have to adjust this....
EG civic hatch
Jan 28, 2004 09:38 AM
len
Nov 11, 2003 09:00 AM
Initial_E
Sep 7, 2001 06:32 PM
