What needs 2 b changed in a K20A2 to make it as stronge a type-r?
Old Nov 20, 2003 | 05:40 AM
Mr.TecH7's Avatar
Default What needs 2 b changed in a K20A2 to make it as stronge a type-r?
What needs to be changed in US RSX-S to make as strong as a JDM RSX-R? What internals need to b changed to make it a type-r.
Is US 6 speed tranny the same as JDM, but just w/o LSD?
Old Nov 20, 2003 | 05:56 AM
f1nal zeros's Avatar
Well to reach DC5R(type R) power you just need a few things.
-ITR cam shafts
-ITR Intake manifold
-Hondata k20a (ITR) Flash
-ITR LSD
-ITR Final Drive
Good Luck.
Old Nov 20, 2003 | 05:58 AM
B18CXr's Avatar
Default Re: (f1nal zeros)
crank, rods, pistons, etc...........
Old Nov 20, 2003 | 06:10 AM
Mr.TecH7's Avatar
Default Re: (B18CXr)
kind of new to the game ( no question is a dumb question)... so i don't need to find a trust worthy spot to get a used JDM K20A, i can get a new RSX-S block and head, n build internals. should i go with type-r or is there better choices?
Old Nov 20, 2003 | 06:53 AM
Well at this point it is entirely up to you.
You can get a complete R swap for around 5-6k. And that includes Engine, Ecu, Tranny. So the LSD and Final Drive will already be included so all you have to do is have the motor installed.
If you wanted to get the S motor it might be a little more work.
You can get a used type S motor for around 3500- 4000.oo which includes Engine, ecu, tranny.
But you will need to purchase and install the ITR parts. Here are the prices on these items more or less.
ITR cams = $500.00
ITR Intake manifold = $320.00
Hondata ITR ecu Flash = $600.oo
ITR LSD = $895.00
ITR Final Drive = $ 325.oo
Plus around 1000k for install of the parts.
So you are looking around $8640.oo.
It might be cheaper to just get the R swap.
Good luck bro.
Old Nov 20, 2003 | 08:44 AM
360's Avatar
360
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f1nal zeros &raquo;</TD></TR><TR><TD CLASS="quote">Well to reach DC5R(type R) power you just need a few things.
-ITR cam shafts
-ITR LSD
-ITR Final Drive
Good Luck.</TD></TR></TABLE>
You forgot to add pistons to that list. The k20a's comp ratio is 11.5:1, as opposed to the k20a2's comp ratio of 11.0:1.
Old Nov 20, 2003 | 01:39 PM
JoeyBallzSI's Avatar
Default Re: (360)
also the intake valves on the type r head are different they use one toda valve and one f20c valve
Old Nov 20, 2003 | 02:13 PM
Mr.TecH7's Avatar
i'm just tryn to go as new as i can with this swap, used engine: sometimes u don't know what u gettn... i can get a new RSX-S engine so i thought it might be cost efficient to build it up. So i'm on the search for a clean K20A or DC5 front clip.
This is a dif. forum topic but does anyone know of a reputible JDM engine importer?
<U>sorry can't IM u back yet... not enough post</U>
Old Nov 20, 2003 | 03:07 PM
Well if you plan on buying a new type S motor/tranny/ecu you beter be prepared to pay around 8k for the set up.
When you purchase a ITR swap the motor has around 10-25k miles on them. So your best bet would be to just go with the ITR set up.
As for importers there are a few shops that stock them.
http://www.j-garage.com
or http://www.autolink.com
Good luck bro.
DVC2008
Northern California (Sales)
Aug 15, 2008 11:57 PM
SLEEPER775
Aug 6, 2007 08:22 PM
jman86
Dec 17, 2006 11:31 AM
bearboy80
28
Sep 9, 2003 09:01 PM
Peter K
May 3, 2003 10:02 AM
