fs: poor man's type r setup w/extra's for $1750.
heres the deal
i have a 96 gsr block (complete from oil pan to head gasket) w/itr pistons, you get new rod bearings and main bearings still in the box. block has about 90k miles on it. in great working cond.
b16a1 head:
itr valves, ported head, skunk2 valve springs and retainers, itr valve cover w/new valver cover gasket, head is complete w/every single nut and bolt, cams, cam gears, new cam seal gasket, gsr (obd-1 injectors) you get everything in a head except for the dist. throttle body and intake manifold.
also i will throw in a jg edle brock header for b's motors, its a 4-2-1 (2pc. header) letting all this go for $1750.
and i am sure theres more parts in this deal that i forgot about.
Modified by b16powwer at 6:23 PM 11/21/2003
b16a1 head:
ko2performance
Engine Machining & Assembly
Mar 15, 2016 10:03 AM
ko2performance
Mar 12, 2016 07:11 PM
