? About JDM 4-1 to Carsound Cat to Stock exhaust piping length
Now say I install the JDM 4-1 with carsound cat. Is this setup the same length as the USDM Headers + USDM cat? Or is the JDM +CS Cat setup shorter/longer than where the us cat bolts on in its way back ? Thanks
The cats come s a universal part, they are then modified with the proper flanges and length to fit a variety of applications. So, as long as the application and which header is used you shouldn't have a bolt up problem. You will have the mismatch/bottleneck at the B pipe though.
If you specified a JDM header and USDM exhaust when you ordered, then it should work out fine.
"You will have the mismatch/bottleneck at the B pipe though"
Does this cause any leaks or problems with the connection?? Or is it more of a performance disadvantage.
Talk to SMSP for an adapter that you can easily have welded in to remove the bottleneck.
I did, works great!
[Modified by FBP_1171, 8:48 AM 9/13/2001]
I did, works great![Modified by FBP_1171, 8:48 AM 9/13/2001]
ednyboo
Apr 26, 2007 05:10 AM
austrian type-R
Feb 16, 2004 02:39 PM
