H22 Turbo: Injector size question
Hi. I just bought some turbo stuff from luckypon7.
Here is the link: https://honda-tech.com/zerothread?id=666927
I will be running 8 lbs off of this setup and I was wondering if my stock injectors will handle this extra amount of air or do you guys recommend bigger injectors? I really don't want to overwork them but I heard that the H22 injectors are good enough for low boost at stock fuel pressure. Anyone with opinions, please let me know. Thanks in advance.
From what i have heard you want to use bigger injectors. I am trying to turbo my f22. Everyone has told me to use 470cc injectors. I don't know if you do but you also will need an afc or v-afc controller, or something of the sort to mix the proper amount of air and gas.
I would go with 550's, just because its a bigger engine and they come stock with 345's, witch is 105 bigger then stock... so go with 450's 440's and if you are lean on the dyno, change em out for some 550's..
DSM blue top 440's will be just fine for about any turbo honda til about 350 wheel horse. I have them in my car now and it runs fine with a little wideband tuning. It all just depends on how much boost your going to run.
You will also need aside from the injectors some sort of fuel management system and a Walbro 255 lph fuel pump. Also depending on your set up you may need an adjustable FPR
yeah i keep reading horror stories everywhere im almost afraid to boost it now...what about emange piggy back? no good...if i just tune it to 6psi and only 6 will it be fine with vafc.....im too poor for aem ems lol
hondaracin24
Dec 15, 2006 03:32 PM
