What do you use to pinch the brake lines ?
Old Nov 19, 2003 | 01:10 PM
BeesDA6's Avatar
Default What do you use to pinch the brake lines ?
Will be using a c clamp to push the caliper piston back in but car has ABS & I dont want the dirty fluid going to the ABS unit. Is pliers good enough to pinch the lines while i let the fluid out of the bleeder screw ?
Old Nov 19, 2003 | 03:55 PM
mugenracer's Avatar
Yes, but get a piece of rubber tubing and cut it length ways and use a strip of it around the brake line so you dont damage it with pliers.
Old Nov 20, 2003 | 07:30 PM
BeesDA6's Avatar
Default Re: (mugenracer)
Cool right on
Old Nov 20, 2003 | 09:52 PM
Sukebei Oni's Avatar
Default Re: (BeesDA6)
use some dikes and a rubber band.
j/k. you can just use some visegrips and a rag wrapped around the line. or buy the tool made for brake lines. i just got a really nice one. all you have to do is squeeze and it holds then when i want to release, i just pull it off.
Old Nov 22, 2003 | 08:59 PM
YoungOne's Avatar
Default Re: What do you use to pinch the brake lines ? (BeesDA6)
The correct way is to first open up the bleeder screw. that way while forcing the piston in the old fluid comes out of the bleeder screw. when your done, wait fo all the bubbles to come out fist before closing up the screw. thats how all the techs do it
daboy155
Suspension & Brakes
Sep 18, 2017 06:59 PM
deerman2701
Honda Civic (2006 - 2015)
Oct 13, 2014 03:29 PM
5spdfrk
Suspension & Brakes
Oct 1, 2009 08:56 AM
itellyawhat
17
Nov 27, 2007 10:44 PM
InvaderTrax
Jan 10, 2007 06:50 PM
