putting the built motor on a bottle, how much will this handle?
i recently built my motor to be boosted eventually. in the meantime, until i get enough money, i need some power. my mods are listed below. any experts out there know about how much of a shot i can handle? i've searched, and not found what i'm looking for. if only people labled their topic titles better, i know this has been discussed before.
With a built motor, you "should" be able to run anywhere from 100-150 shot. You'd probably want to go with a wet setup, since the dry setup is only good for up to 75~100 at the most. After that, fuel pressures are too high and it's a guessing game then.
But since a "good" wet setup is like $700-1000...just save up for the turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98CTRCoupe »</TD></TR><TR><TD CLASS="quote">With a built motor, you "should" be able to run anywhere from 100-150 shot. You'd probably want to go with a wet setup, since the dry setup is only good for up to 75~100 at the most. After that, fuel pressures are too high and it's a guessing game then.
i can get you a custom plate kit made. i have pics at my house if you want. it comes w/pro-big shot n2o noid, cheater fuel noid, 4 fogger nozzels(which i will tap and screw into plate), and all the hard line and fittings needed to run it. all you have to get is a bottle, feed line, and button. i can get all that also, but shipping on a bottle isnt worth it, you can get your own cheaper. you can upgrade to all soft line for about $100 extra.
all of that for $500. this is made as a plate/dp system for our ludes, which isnt made by any company. which i designed for the same purpose as you are looking for.
min shot is 80. and you MUST get an upgraded fuel pump to run this. its also advised you at least have a wideband the first time you spray cause all engines are a little different in their fuel usege. on a dyno would be the best for first usege.
</TD></TR></TABLE>i can get you a custom plate kit made. i have pics at my house if you want. it comes w/pro-big shot n2o noid, cheater fuel noid, 4 fogger nozzels(which i will tap and screw into plate), and all the hard line and fittings needed to run it. all you have to get is a bottle, feed line, and button. i can get all that also, but shipping on a bottle isnt worth it, you can get your own cheaper. you can upgrade to all soft line for about $100 extra.
slowhatchcali
Feb 2, 2007 06:40 AM
idra
Mar 17, 2006 03:53 AM
