clutch getting very squeaky and seems to be more resistance..
Old Nov 19, 2003 | 11:32 AM
geminis2k's Avatar
Default clutch getting very squeaky and seems to be more resistance..
My clutch is getting squeaky and there seems to be moe resistance when pushign down, feels heavier - This is most likely???
Clutch has 70 something k on it and I don't believe it's ever been changed..
Old Nov 19, 2003 | 11:41 AM
geminis2k's Avatar
Default Re: clutch getting very squeaky and seems to be more resistance.. (geminiGSR)
and yes I did a search but I'm confused as to why it feels like the clutch is HARDER
Old Nov 20, 2003 | 10:57 AM
roadrunner's Avatar
Is the squeak coming from the inside of the passenger compartment or from outside, such as from the front of the car? If it's from the inside, a pin that acts on the pushrod to the clutch master cylinder tends to squeak when it wears. A good shot of white lithium grease usually takes care of it. If it's from the outside, the clutch fork is probably squeaking, in which case you may as well do a clutch job to get to it.
If your pedal pressure is increasing, it might be due to the seals in the master and slave cylinders becoming worn so they stick to the sides rather than slide smoothly within it. Try flushing your fluid.
Old Nov 20, 2003 | 11:00 AM
EL Vap133's Avatar
Does it lag when you are shifting?
Old Nov 20, 2003 | 11:05 AM
geminis2k's Avatar
Default Re: clutch getting very squeaky and seems to be more resistance.. (EL Vap133)
it lags, if u mean that my clutch is slipping.. hehe.. car wont even chirp 2nd anymore
Old Nov 20, 2003 | 11:06 AM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geminiGSR &raquo;</TD></TR><TR><TD CLASS="quote">and yes I did a search but I'm confused as to why it feels like the clutch is HARDER</TD></TR></TABLE>
Either the slave cylinder, fork, throwout bearing, or disc is going out.
A common problem is that a spring in the disc will start to pop out and will not let go of the clutch pressure plate, hence that causes the added pressure.
Old Nov 20, 2003 | 11:33 AM
J337_UNIT's Avatar
Default Re: clutch getting very squeaky and seems to be more resistance.. (P1mpSlap)
chatter or squeek is usually a bad throw out bearing
blacklabel14
Feb 3, 2011 12:32 PM
Dre_559
May 28, 2009 08:23 PM
veilsides2000
Honda S2000
Jan 30, 2009 02:20 PM
tvman
Jul 16, 2005 11:30 AM
Paste
Aug 15, 2002 08:49 PM
