Trying to make a Civic Type R engine
Guest
Posts: n/a
The two engines I'm sitting on are a B16AII with hydro tranny (jspec)-
and a 94 GSR swap with tranny as well - I have both ecu's - ob1
currently i'm running the B16 swap in a cx hatch back -
I heard I could use the bottom end of the B18C block and the top of the B16?
Did I hear wrong?
Did I hear wrong?
that wouldn't make a CTR engine. CTR engine is a B16B.
What you're thinking of is "similar" to ls/vtec only you're just swapping one head for another since you'll be using a VTEC head and block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THAiGuYDc2 »</TD></TR><TR><TD CLASS="quote">get the B16B</TD></TR></TABLE>
actually i would recommend getting a JDM ITR motor over the b16b. i don't think the price is much different and you'll get better header, gearing, hp and tq.
You can run a B16 head on your B18C block for a strong hybrid motor. If it were me, I would utilize the fact that I have two great Honda engines and combine the two to make one hell of a frank motor because you would have an LS/VTEC with a block already designed for VTEC so you wont have to worry about keeping it under 7 grand and ******* with the oil galley and the oil fittings to convert a B18A/B block to make VTEC function. Plus you could just buy a set of CTR cams and a Type R ECU and you would have pretty close to a CTR (I'm probably going to get yelled at by another Honda geek for saying that). For the money you would spend on a B16B, this would be more effective, plus, there is no replacement for displacement. Goodluck and godspeed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeeAteTeenRacer »</TD></TR><TR><TD CLASS="quote">You can run a B16 head on your B18C block for a strong hybrid motor. If it were me, I would utilize the fact that I have two great Honda engines and combine the two to make one hell of a frank motor because you would have an LS/VTEC with a block already designed for VTEC so you wont have to worry about keeping it under 7 grand and ******* with the oil galley and the oil fittings to convert a B18A/B block to make VTEC function. Plus you could just buy a set of CTR cams and a Type R ECU and you would have pretty close to a CTR (I'm probably going to get yelled at by another Honda geek for saying that). For the money you would spend on a B16B, this would be more effective, plus, there is no replacement for displacement. Goodluck and godspeed.</TD></TR></TABLE>
you fail to see the point, there is no piont of putting a b16 head on a GSR block if you already have a GSR engine fully assembled. All you are going to do is get less mild cams w/ less compression!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeeAteTeenRacer »</TD></TR><TR><TD CLASS="quote">Hence the civic type R cams. And putting a B16 head on a B18C block will raise compression.</TD></TR></TABLE>
sorry bud, but your wrong, it will lower compression
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bolivianstrtwpn »</TD></TR><TR><TD CLASS="quote">
sorry bud, but your wrong, it will lower compression</TD></TR></TABLE>
Agreed. GSR heads raise compression, B16's lower it. Its the combustion chamber design.
range
Nov 19, 2003 11:40 AM
