B18b on B18a tranny?
Old Nov 19, 2003 | 11:21 AM
sleeper[Xsi]'s Avatar
Default B18b on B18a tranny?
Hey guys,
I'm looking to buy a 91 teg, for about 1500, but the catch is that it either doesnt have a motor or it has a blown motor. So, my question is will a B18B block work with a B18A tranny? Or will i have to get a long block?
Old Nov 19, 2003 | 11:23 AM
dan89crxsi's Avatar
Default Re: B18b on B18a tranny? (sleeper[Xsi])
yes, the b18a tranny will work
Old Nov 19, 2003 | 11:25 AM
Default Re: B18b on B18a tranny? (dan89crxsi)
do i need to make any mods? New ECU, harness, anything?
Modified by sleeper[Xsi] at 8:41 PM 11/19/2003
Old Nov 19, 2003 | 11:53 AM
dan89crxsi's Avatar
the b18a uses a cable tranny and the b18b uses hydro im not sure of any changes in wiring/setup hasport sells a kit to use a cable tranny on hydro applications i believe however I am unsure
Modified by dan89crxsi at 4:13 PM 11/19/2003
Old Nov 20, 2003 | 10:48 AM
thanks man
Old Nov 20, 2003 | 10:53 AM
96-EJ6 B18C's Avatar
You shouldn't have to get the conversion kit because the 91 teg is a cable car and the tranny is also cable. As far as wiring you will have some wiring to do if you are putting the an OBDI motor in an OBD0 car.
Old Nov 20, 2003 | 10:55 AM
LODOSS's Avatar
if you keep the same distributor and fule injectors it should be a straight drop in. i have a friend with a 4 door 91 teg it is an automatic with a good running engine.. for 1500.. but i think u can get a better deal if you find something closer.
Old Nov 20, 2003 | 11:01 AM
EL Vap133's Avatar
Only thing you have to do is the wiring...
Old Nov 20, 2003 | 11:04 AM
I Want An Si's Avatar
use the wiring from the original engine and keep your injectors and dizzy and youll be set....
youll have to do something with the thermoswitch sensor.....theyre different plugs
Old Nov 20, 2003 | 02:41 PM
veggiemaster's Avatar
Default Re: B18b on B18a tranny? (I Want An Si)
if its the motor, remember, the b18a is non-odb, and the b18b is.
Specialk
Apr 8, 2007 08:58 PM
n2oef
Jul 30, 2006 12:42 PM
540i6
14
Jan 19, 2005 01:06 PM
MR. ARIZONA
Sep 2, 2002 02:17 AM
Dru-Si
May 26, 2001 08:48 PM
