Changing engine coolent
Old Sep 12, 2001 | 03:27 PM
TheShad0w's Avatar
Default Changing engine coolent
Whats the best/proper way of doing so?
I'm about to be swapping several heads on engines, and I've never messed with the coolant before. best way to drain, best way to refill, best fluid to use?
Old Sep 12, 2001 | 05:54 PM
johng's Avatar
Default Re: Changing engine coolent (TheShad0w)
Remove the plug on the bottom of the radiator and drain the radiator, remove the drain bolt in the block and drain the block, and refill with coolant (your favorite brand) properly mixed with water. I try to go for a 60-40 split favoring coolant.
Old Sep 13, 2001 | 01:04 PM
JunkeeCrx's Avatar
New User
Default Re: Changing engine coolent (johng)
if you have a bleeder for the block dont forget to bleed that as well.
Old Sep 13, 2001 | 05:47 PM
976's Avatar
976
New User
Default Re: Changing engine coolent (JunkeeCrx)
Green and gold coolent is best choice for japanese radiators. Since the JDM stuff doesn't come here, it works the best, protection and funtion wise. I read articles in motor trend.
Also, remove the radiator cap and oxygen caps so all the fluid comes out...
Old Sep 13, 2001 | 07:30 PM
BoM's Avatar
BoM
Default Re: Changing engine coolent (prsi)
where do u put the old coolant? where do we recycle that stuff?
Old Sep 14, 2001 | 05:47 AM
CardDealer's Avatar
Banned
Default Re: Changing engine coolent (bommiE)
Modified by CardDealer at 4:20 AM 11/16/2006
Old Jul 3, 2004 | 12:44 PM
xdjoynerx's Avatar
Default Re: Changing engine coolent (schlit)
this is years old, but i need to know.
seriously where can you recycle this stuff? should i literally just pour it down the drain with alot of water?
also... how can i flush the whole system? just take the top rad hose off and turn the hose on?
Old Jul 4, 2004 | 12:49 PM
xdjoynerx's Avatar
bump
Old Jul 4, 2004 | 01:30 PM
Sliced Beard's Avatar
Default Re: (xdjoynerx)
be shure to get Silicate free coolant
silicates deteriorate rubber and aluminum=bad for honda
Old Jul 4, 2004 | 07:11 PM
xdjoynerx's Avatar
Default Re: (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">where can you recycle this stuff? should i literally just pour it down the drain with alot of water?
Old Jul 4, 2004 | 07:25 PM
to flush ht esystem properly you will need to get a coolant flush kit/chemical from your local auto parts store
Old Jul 4, 2004 | 09:18 PM
Two_K Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xdjoynerx &raquo;</TD></TR><TR><TD CLASS="quote">this is years old, but i need to know.
also... how can i flush the whole system? just take the top rad hose off and turn the hose on?</TD></TR></TABLE>
Contact your city's waste management office, they will tell you how to dispose of antifreeze.
And your second question, go pick up a prestone flush n' fill kit from pepboys. It works great and is very easy to use.
Old Jul 4, 2004 | 09:34 PM
vtekstorm's Avatar
Default Re: (Two_K Si)
to dispose it put it in a container and take it to an auto shop. see of they can dump it for you cuz i know u can do that with oil. take it to a pep boys or somehing like that
Old Jul 4, 2004 | 10:42 PM
xdjoynerx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si &raquo;</TD></TR><TR><TD CLASS="quote">
And your second question, go pick up a prestone flush n' fill kit from pepboys. It works great and is very easy to use. </TD></TR></TABLE>
well i saw a kit... it just looks like a t fitting for the upper rad hose... thats why i was wondering if i would just disconnect one end of the hose and and turn the water on
Old Jul 5, 2004 | 01:35 AM
Quitripin's Avatar
don't drain it down a drain coolant is toxic! take it too shucks or napa
atikovi
Oct 7, 2010 05:49 PM
xXViperXx
May 6, 2010 06:39 AM
DIRTYsouthBB6
Jul 13, 2006 09:51 AM
LAKER HATER
Nov 24, 2004 07:13 PM
kkim
Apr 23, 2003 02:30 PM
