**** what proportioning 40/40 valve to get and brake booster?
Old Nov 19, 2003 | 07:39 AM
Charlie Moua's Avatar
Default **** what proportioning 40/40 valve to get and brake booster?
Well i'm getting a set of 94gsr complete brake for my 90 ef hb si for dirt cheap.
I wanted to know what OTHER parts i should pick up so that I get the best results or my brakes. Here is what i have down so far.
1) goooood brake pads!!!
2) SS lines from Stan(flamenco-t)
3) 90-91 civic ex master cyclinder 15/16
4) brake booster........ (is that the black thing the MC bolts on to? which one should I upgrade too?
5) what 40/40 <U>proportioning valve to get?</U> since i will have larger disbrakes on all 4 coners?
Old Nov 19, 2003 | 07:50 AM
Mr Furball's Avatar
Default Re: **** what proportioning 40/40 valve to get and brake booster? (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">4) brake booster........ (is that the black thing the MC bolts on to? which one should I upgrade too?</TD></TR></TABLE>
Yes it's the black thing, 90-91 Civic EX will be fine with the MC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">5) what 40/40 <U>proportioning valve to get?</U> since i will have larger disbrakes on all 4 coners?</TD></TR></TABLE>
90-93 integra should be fine.
Old Nov 19, 2003 | 07:58 AM
Default Re: **** what proportioning 40/40 valve to get and brake booster? (FURBALL B-16)
thanks.
is there a difference in the brake booster of the 91 EX over the ef si?
how much does a remanufacture one cost?
Also what does the 90-93 40/40 proportioning valve look like?
should i buy new or ok to buy used?
Old Nov 19, 2003 | 08:07 AM
Mr Furball's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">thanks.
is there a difference in the brake booster of the 91 EX over the ef si?</TD></TR></TABLE>
Yes, the Ex has the 15/16 MC and booster, the ef and si have the smaller one. Still good but why waste your money when you can have something bigger and it costs the same.
how much does a remanufacture one cost? </TD></TR></TABLE>
I called Pep Boys and A reman was under 100.00
should i buy new or ok to buy used? </TD></TR></TABLE>
Kind of hard to explain, Or maybe I am just bad at explaining, but used is just fine, go to a local junk yard and just ask for one and they can tell you the price, I would buy a used prop valve and a reman MC. The booster can be used also.
Old Nov 19, 2003 | 01:56 PM
Alan Wil's Avatar
What kind of knuckles are you going to use? The GSr ones may affect your steering geometry. Look over the below links, you may find some info that may help.
Does your car already have the 10.3 front brake discs like the 90-91 Civic Ex sedan? If not you may have to 'upgrade" the steering knuckles so the brake disc is centered properly.
Here's a link that may help: http://hybrid2.honda-perf.org/tech/bigbrakes.html
If you find out anything about using 91 Integra LS steering knuckles on a 90 Civic please post here, it’s pretty similar to what your doing.
https://honda-tech.com/zerothread?id=668258
PS: Some have used an 89-91?? Prelude M/C as it is 15/16 also, will bolt right up to stock booster. Above link has info about that.
Thanks,
89efDUSTY
Aug 14, 2007 07:07 AM
lollypopking
Jan 3, 2005 05:21 PM
TEGPOWER44
Sep 8, 2003 04:19 PM
hybrid_KJ
Jun 9, 2002 01:27 PM
