i need help (starting swap trouble!) :(
Old Nov 19, 2003 | 07:36 AM
Jstue's Avatar
Default i need help (starting swap trouble!) :(
i have a 1993 honda civic dx coupe that came stock with a d15, i took that out and put in a d16y8 im using all stock dx wireing harness dx ecu (orderd a p28 but its not hear yet. but that sholdent matter right it still should be running!? just no vtec?) i am aslo using stock dx injectors (cause my harness wouldent plug into the y8 injectors) and the stock dx distributer cause the y8 dist dident have the hookups for my dx wireing harness and it wasent sparking. now when i turn it over after messing with the timing it fires up but you have to keep the rpms up or it will die, also gas is coming out of the tail pipe its just not right? will it run? how can i make it run?
ps aslo im using the y8 intake mani but it dident have the sensors that the d15 mani did so i took the sensors off and just pluged them into my harness hoping it will just throw a code.
also there is a plug coming out of the motor below the cam gear and above the belt for the altenator its just dangling my dx wiring harness dosent support it anywere...
any help would be mutch apriciated and if you can give me a number to wear i can find help that too would be mutch apriciated. THIS SUCKS! its been a week and i want my car out of my school shop!
Old Nov 19, 2003 | 01:07 PM
mor ber's Avatar
Default Re: i need help (starting swap trouble!) :( (Jstue)
dude you have problems!
trouble with this is you pieced so many things together it's hard to figure what's not working. id check those sensors to find out exactly what they do first. sorry i couldn't help more. good luck.
rayvo
14
Nov 16, 2009 10:33 AM
RicedREX
Aug 23, 2004 08:38 PM
FAST AS
15
Dec 24, 2003 03:12 PM
Jstue
12
Nov 20, 2003 08:10 PM
lilred92hatch
Mar 12, 2003 03:54 PM
