Windshield washer nozzles on hood (Spray pattern)?
All the hondas I've had have always had the same washer jets, they just spray 2 lines of liquid halfway up the windshield. I've been in other cars, of which specifically I can't remember, which actually spray a wide pattern over the whole windshield which is much better at coverage and wetting every area quickly. Anyone know if it is possible to get these nozzles that would fit in the holes in the hood of a 97 Accord and would connect properly to the supply hoses for the fluid under the hood? Any help would be great.
just go grab some 98-02 nozzles and gaskets. if they dont fit oh well you didnt spend that much money and u can let others know if it works or not.
-chris B
-chris B
Did you know you can adjust the nozzles using a pin or needle. They swivel and can be adjusted to how you want them to spray. Plus, doing this will clean the nozzles out as well. If you still don't like that, I bought some awhile back to put on my CF hood (the stock ones would not fit properly). I can't remember the name of the brand, but they had a wide, fan-like spray pattern. I really liked the way they worked. The only thing you would need to do is paint them the color of your car. I did this with a small can of car paint that matched my car and then sprayed some clear coat on it. They turned really good. The washers only cost about $10. If I happen to find the package, I will let you know.
EGcivicBoy
11
Nov 18, 2003 05:56 PM
2002, 98, accord, adjust, adjustment, honda, nozzle, nozzles, pattern, replacement, spray, tampa, washer, wider, windshield
