Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Ground Control Upper shock mounts
Old Nov 19, 2003 | 12:37 AM
EH3-R's Avatar
Default Ground Control Upper shock mounts
i searched everywhere, but no luck. where can i find these??? good prices? thanks
Old Nov 19, 2003 | 03:58 AM
solo-x's Avatar
Default Re: Ground Control Upper shock mounts (BoostedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedHatch &raquo;</TD></TR><TR><TD CLASS="quote">i searched everywhere, but no luck. where can i find these??? good prices? thanks</TD></TR></TABLE>
Here
Old Nov 19, 2003 | 04:52 AM
JeffS's Avatar
Default Re: Ground Control Upper shock mounts (solo-x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo-x &raquo;</TD></TR><TR><TD CLASS="quote">
Here </TD></TR></TABLE>
imagine that...
Old Nov 19, 2003 | 05:16 AM
Xian's Avatar
Default Re: Ground Control Upper shock mounts (JeffS)
now that we've covered the basics of where to find them...
does anyone have an opinion as to whether these are a reasonable substitute for shortened body shocks? Seems like they'd serve roughly the same purpose (increase wheel travel) but be hella less expensive than shortening the shocks...?
Old Nov 19, 2003 | 05:36 AM
Want2race's Avatar
Default Re: Ground Control Upper shock mounts (Xian)
I have them in My BMW. Its amazing how much they firmed up the ride... It not rides like a barge board! but who cares about that when you have the added :"bling" it brings to the table!!
Old Nov 19, 2003 | 07:34 AM
Cheap Bastard's Avatar
New User
Default Re: Ground Control Upper shock mounts (Want2race)
I like them. It defenitely help to bring the shock travel to it's proper range. But it doesn't help much for higher spring rates. You also have to drill out you bushing to fit Koni or Bilstein shocks. The shock shaft is too big, I think it was meant for stock shock shaft diameter.
Old Nov 19, 2003 | 07:40 AM
.RJ's Avatar
.RJ
Default Re: Ground Control Upper shock mounts (Cheap Bastard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cheap Bastard &raquo;</TD></TR><TR><TD CLASS="quote">I You also have to drill out you bushing to fit Koni or Bilstein shocks. </TD></TR></TABLE>
Heh, no you dont
solo-x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cheap Bastard &raquo;</TD></TR><TR><TD CLASS="quote">... But it doesn't help much for higher spring rates.</TD></TR></TABLE>
huh? what do you mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">You also have to drill out you bushing to fit Koni or Bilstein shocks. The shock shaft is too big, I think it was meant for stock shock shaft diameter.</TD></TR></TABLE>
or use the bushing/sleeve that came with your koni's. fit's right in there.
nate
Old Nov 19, 2003 | 07:42 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solo-x &raquo;</TD></TR><TR><TD CLASS="quote"> fit's right in there.</TD></TR></TABLE>
And if it doesnt, push harder...use a socket... it'll go.
Old Nov 19, 2003 | 07:47 AM
solo-x's Avatar
Default Re: Ground Control Upper shock mounts (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
And if it doesnt, push harder...use a socket... it'll go.</TD></TR></TABLE>
:cringe: you use this method with your gf too?
as to whether or not these peices are a good alternative to shortened shocks, that's up to your definition. they do work as advertised. they are substantially cheaper then shortened shocks, though shortened shocks do have the advantage of _slightly_ more travel. whichever way you go, keep this in mind. increasing shaft travel by more then 1" greatly increases your chances of uca to strut tower contact.
nate
Old Nov 19, 2003 | 08:00 AM
carl_aka_carlos's Avatar
*sighs* that's why i wish we could run custom uprights in STS
Old Nov 19, 2003 | 08:27 AM
jsi's Avatar
jsi
Default Re: Ground Control Upper shock mounts (carl_aka_carlos)
Are these legal in SP/STS? The way I understand the rules, technically the only allowance allowing strut mount changes is in the camber plates installation for mac struts...
Old Nov 19, 2003 | 08:45 AM
Tyson's Avatar
Default Re: Ground Control Upper shock mounts (jsi)
consider it part of the shock, which is free. we've been thru this before....
Old Nov 19, 2003 | 08:51 AM
Xian's Avatar
my understanding is that they are legal since the strut/spring/GC shock mount assembly still mounts through the stock mount holes and in the stock location.
Old Nov 19, 2003 | 09:08 AM
jisu009's Avatar
I run them on my 4th Gen and have never had any problems with bump steer or running out of travel. My car is however a DD, HPDE'er, and not a race car.
I will most likely use a combination of the GC upper mounts AND a shortened shock on my race car....
Old Nov 19, 2003 | 09:15 AM
GSpeedR's Avatar
Default Re: Ground Control Upper shock mounts (jisu009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 &raquo;</TD></TR><TR><TD CLASS="quote">I will most likely use a combination of the GC upper mounts AND a shortened shock on my race car....</TD></TR></TABLE>
I wonder if you'd have coil binding issues with a combination of the GC mounts, with shortened shocks, and with a super low ride height (3" below stock?).
Old Nov 19, 2003 | 10:10 AM
jsi's Avatar
jsi
Default Re: Ground Control Upper shock mounts (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">consider it part of the shock, which is free. we've been thru this before....</TD></TR></TABLE>
ok, thanks.
Anyone know if these will work only with the GC coilovers or other springs as well (ie, H&R or Neuspeed race springs)? I know the GC site says Only for use with Ground Control coil over kits..., but it will be nice to know if they'd work with the forementioned other springs. TIA...
Old Nov 19, 2003 | 11:54 AM
.RJ's Avatar
.RJ
They'll work with 2.5" ID springs....
Old Nov 19, 2003 | 12:03 PM
solo-x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">They'll work with 2.5" ID springs.... </TD></TR></TABLE>
they'd probably even fit a 2.25" ID spring if you left out the urethane isolater.
nate
Old Nov 19, 2003 | 12:32 PM
krshultz's Avatar
I like 'em. Front end of the car doesn't wash out anymore.
That said - in the process of installing them so its hard to precisely phrase how much better they made the car.
One other thing - be careful with hood clearance. I had to pound on some of the inner webbing with a hammer to clear the top of the passenger side Koni adjuster once these were installed.
Old Nov 19, 2003 | 08:00 PM
GBRacing's Avatar
I run them too. My car is now 5 inch off the groud in the front. Having the car this low, I almost have 4 degrees of negative camber Since I've put them on, I've race Daytona and Sebring. At Daytona, the car was simply awesome. At Sebring, the car turns in really when but it doesn't handle some of the bumps too well because I don't have a lot of travel. I'm considering raising the car half an inch to get it to handle some of the bumps a little better.
Old Nov 19, 2003 | 10:02 PM
Lo-Buck EF's Avatar
Default Re: (ITACRX)
i had them. they do exactly what there supposed to do. increase travel. if u do a search, u should find some threads about them.
-spenc
Old Dec 3, 2003 | 11:31 PM
TeamSlowdotOrg's Avatar
Default Re: (VX)
I'm happy with mine.
Old Dec 3, 2003 | 11:58 PM
jisu009's Avatar
Default Re: (SiLooksStock)
Your artistic skillz amaze me....
Old Dec 4, 2003 | 05:20 AM
p0pe's Avatar
When we installed my koni's we had to bore out the bumpstop because the rod diameter was too big for it. They're Neuspeed SP3 series if that matters.
