USDM P73 vs. JDM P73
Old Nov 18, 2003 | 11:39 PM
Gr8Wyt3's Avatar
Default Will a usdm p73 be plug and play with ajdm p73???
hey guys i posted this question in the civic forum lol. i want to make my civic legal in cali so i need to know this!! if it is, is there anything else i have to wire up???
Old Nov 19, 2003 | 09:46 AM
daddymaxx's Avatar
What kidn of motor is it on?
I believe the JDM p73 will work on both USDM and JMD motros.
But the USDM will not work on teh JDM motor. The USDM P73 looks for the crank fluctuation sensor, 2nd O2 sensor, Oil pressure sensor. The JDM motor doesn't have these.
Old Nov 20, 2003 | 08:10 PM
Gr8Wyt3's Avatar
Default Re: (daddymaxx)
what would u guys suggest i do then???
Old Nov 20, 2003 | 11:59 PM
cheezthis's Avatar
Chipped P28 maybe? I don't know the cali laws.
Old Nov 23, 2003 | 07:50 PM
Gr8Wyt3's Avatar
Default Re: (cheezthis)
anyone else, could i use a usdm p72?
Old Nov 24, 2003 | 03:11 AM
Jon D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daddymaxx &raquo;</TD></TR><TR><TD CLASS="quote">What kidn of motor is it on?
But the USDM will not work on teh JDM motor. The USDM P73 looks for the crank fluctuation sensor, 2nd O2 sensor, Oil pressure sensor. The JDM motor doesn't have these.</TD></TR></TABLE>
Yeah beleive it or not....my jdm b18c wouldnt start and it ended up being the extra o2 sensor. It should work though as stated. Good Luck
Old Nov 25, 2003 | 03:58 PM
Gr8Wyt3's Avatar
Default Re: (jh4dc23spoon)
i can do the 2nd o2 sensor but crank fluctuation sensor and the oil presure how would i hook that up??? would i even need to hook it up? would i throw a code?
Old Nov 25, 2003 | 04:28 PM
Gr8Wyt3's Avatar
Default Re: (B18RCoupe)
anyone??? the help will be much appreciated
Old Nov 26, 2003 | 11:32 PM
t's Avatar
t
Sell/Trade your USDM for a JDM one.
Old Nov 27, 2003 | 12:27 AM
Gr8Wyt3's Avatar
Default Re: (t)
bump
Old Nov 27, 2003 | 10:39 AM
GreenD's Avatar
Default Re: Will a usdm p73 be plug and play with ajdm p73??? (B18RCoupe)
as far as legality, all jdm ecu's are illegal in cali. besides the extra sensors, the smog machines cant read jdm ecu's. its not to say a jdm ecu wont work, it will, but it probably wont pass smog or at least it shouldnt.
i have a 98 usdm itr ecu for sale if interested. check my sig..
Old Dec 1, 2003 | 11:10 AM
Gr8Wyt3's Avatar
Default Re: Will a usdm p73 be plug and play with ajdm p73??? (GreenDestiny)
how would i hook up the crank fluctuation sensor, and the oil preasure sensor
Old Dec 2, 2003 | 05:56 AM
voltageGSR's Avatar
i am using a usdm p73 ecu with my JDM ITR engine. I also have a JDM P73 ecu
if you are interested. When I did the swap in my 2000 GSR I used the orginal GSR harness which wouldn't plug up into the JDM P73 (OBD2.1 vs. OBD2.2)
so I had to find a USDM P73 ecu; luckly I did. The second O2 sensor was not
a problem becuase I was using a DC sports header and CATCO converter (forget which had the extra opening) but one of them did. Secondly, the people that did the swap had to swap out the GSR part with teh crank fluc in it; into my ITR.
I didn't think it was the oil pressure sensor; I thought it was the coolant sensor
which didn't hook up into the JDM thermostat housing...this is a problem I'm still
trying to fix. I was told I could extend the wire and attach it to the sensor
on the back of the ITR block; but can't seem to find it (supposedly next to the oil filter). Anyone know more let me know. I have some pics of the sensor and
the spot I found on the back of the block.
http://briefcase.yahoo.com/ishaqsyed@sbcglobal.net
under My Documents
shiux
Oct 20, 2007 09:58 PM
i_HeArT_EgS
15
Jan 19, 2006 06:31 PM
VTEC_1
May 9, 2003 09:39 PM
SlipoftheCondom
Nov 26, 2002 09:08 PM
