differences between OBD0 and OBD1 B16A heads??
Old Nov 18, 2003 | 10:23 PM
turbohf's Avatar
Default differences between OBD0 and OBD1 B16A heads??
yeah i know the cams are slightly different and there is a different dizzy on each but is there any real differences?
can i bolt a OBD0 head onto a OBD1 car with the OBD1 dizzy and be coo??
anything else?
Old Nov 19, 2003 | 07:43 AM
mmuller's Avatar
Mad Scientist
Default Re: differences between OBD0 and OBD1 B16A heads?? (turbohf)
yes, it will bolt up just fine, there aren't many differences; beside the cam griddle beides extrude on one and cast on the other one; 1st gen. head also has less casting flaws. you would have to switch your thermo. water neck with the obd1 one for the coolant temp sensor
Old Nov 19, 2003 | 10:35 PM
turbohf's Avatar
Default Re: differences between OBD0 and OBD1 B16A heads?? (mmuller)
Old Nov 20, 2003 | 07:28 AM
Davep's Avatar
The coolent temp sensor that you're talking about is actually on the block not the head.
Syper
Jul 1, 2012 10:53 AM
wfocrx
Sep 13, 2006 06:29 PM
Brian_92GSR
Mar 25, 2005 11:24 PM
