Intake Manifold Problem
Old Nov 18, 2003 | 10:16 PM
Spectral49's Avatar
Default Intake Manifold Problem
I just did a auto to manual swap and also swapped my intake manifold for a manual one. But i am having trouble with iavc, the one on the manual im has 2 prongs , while the one on the auto has 3 prongs. Does anyone know how to fix this?
this is on a 96 civic with a d16y8
Old Nov 18, 2003 | 10:19 PM
civicrtype's Avatar
Default Re: Intake Manifold Problem (Spectral49)
are u using the auto ecu or the 5spd? if the 5spd changet the 3 wire iacv plug to the 2 wire (just dont use the orange wire). If you are still using your auto ecu then I would suggest using your old tbody so that the iacv can be plugged in so that your car will idle.
Old Nov 18, 2003 | 10:22 PM
Spectral49's Avatar
Default Re: Intake Manifold Problem (civicrtype)
im using the 5speed ecu, so i would have to cut off the auto 3 prong plug and attach the manual 2 prong one without the orange wire?
Old Nov 18, 2003 | 10:46 PM
civicrtype's Avatar
exactly
Old Nov 18, 2003 | 11:00 PM
Spectral49's Avatar
Thanks for all the info
Old Nov 18, 2003 | 11:50 PM
civicrtype's Avatar
heres a perfect thread with pics to help u https://honda-tech.com/zerothread?id=558245
Mikes2000civicsi
Feb 24, 2010 11:56 AM
JokerX-1.6T
Aug 22, 2006 07:59 PM
singlehx
May 6, 2005 06:26 PM
s73
Jun 10, 2004 11:43 PM
Stoich
10
Mar 22, 2004 03:38 PM
