Intermediate shaft.....neep help asap/!!!!!!!!!!!!!
as the topic states what intermediate shaft do i need for a 95 ls motor???????i have a 92 hatch with the LS motor.....mine is leaking and a metal ring thats suppose to be secure is lose ..also my driver side makes a clicking noise when i accel from 1st to 2nd.....is the axle bad as well? i pulled it tonite and no leakage from axle only shaft.........also is there a seal i have to replace thank you..........
First off, if it's leaking at your tranny then you need to replace the axle seal (rubber ring gasket... cost $2 from Honda). Second, depending on what driver side axle you're running, you want to use the same B-series intermediate shaft for that specific driver side axle. Example: 92 Integra driver side axle, use the 90-93 Integra intermediate shaft since the 92 Integra axle has a male end and the mid shaft has a female end. If you have a 95 Integra driver side axle, use the 94-01 Integra intermediate shaft, as the 94+ Integra driver side axles have a female end and the mid shafts have a male end. The clicking is most likely your joints going bad in the axle.
Hybrid axle: 90-93 Integra axle shaft mated with ED6 axle end in order to use ED6 spindle/hub assemb
integrawow
Jul 2, 2007 02:20 AM
B16CRXT
Jun 23, 2006 02:05 PM
Burlyirishdude
Apr 23, 2006 10:28 AM
superslowhatch
Apr 27, 2002 11:42 PM
