00 civic dx
what mounts will i need to drop a b-series motor into my 00 civic dx, someone on another forum said all i need is the rear 99-00 Si mount to make swap work, is this true? thank you h-t guru's
I
I
Rear transmission mount bracket - 1999-00 Civic Si - 56827-S04-N10 $28.86 Reuse the stock rubber mount.
Driver's side engine mount bracket - 1999-00 Civic Si - 11910-P30-000 $40.12. Use the stock Civic 96-00 bolt studs and all other stock parts at this location.
Front transmission mount bracket - 1994-01 Integra or 1999-00 Civic Si. Use the stock Civic 96-00 end rubber mount and bolt stud.
A/C mount bracket - 1993-97 Del Sol. Use the stock Civic 96-00 A/C compressor.
Upper transmission mount bracket - Stock Civic 1996-00.
drowzysleeper
Sep 17, 2005 09:00 AM
GeekinEK
Nov 21, 2004 10:41 AM
