skunk2 cams stage????
Old Nov 18, 2003 | 09:33 PM
swiftstyles's Avatar
Default skunk2 cams stage????
sup ya, I bought my car off someone who had previously built the head with skunk2 camshafts. Im doing a vavle job soon but don't know the stage of the cams so I can figure out the specs. Is there any visible signs that I should look for when I remove the vavle cover.
Old Nov 18, 2003 | 09:35 PM
TeStUdO's Avatar
Default Re: skunk2 cams stage???? (swiftstyles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swiftstyles &raquo;</TD></TR><TR><TD CLASS="quote">sup ya, I bought my car off someone who had previously built the head with skunk2 camshafts. Im doing a vavle job soon but don't know the stage of the cams so I can figure out the specs. Is there any visible signs that I should look for when I remove the vavle cover.</TD></TR></TABLE>
Im pretty sure you would have to check the specs of the lobes.
Old Nov 18, 2003 | 09:44 PM
Default Re: skunk2 cams stage???? (TeStUdO)
check the specs and problably run it by skunk2? Your probably right, Hoping there would be an easier way like casting or part # on the cams.
Old Nov 19, 2003 | 09:20 AM
doublejz's Avatar
pull off your distributor and look for one of the following
Skunk2 Stage 1 H01
Skunk2 Stage 2 h003
Skunk2 Stage 3 s10 and s8
For example, these are stage 1
Old Nov 19, 2003 | 11:26 AM
King Tut33's Avatar
There is a casting and writing on the end. Mine say H08 IN and H08 EX on the ends for the Skunk2 stage2 and they have a circled 2 stamped towards the middle of the cam.
10000rpm
Oct 31, 2004 01:59 AM
SystemGSR
Apr 4, 2004 10:23 PM
