Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Anybody have Fastbrakes upgrade?
Old Nov 18, 2003 | 09:02 PM
S-Type1's Avatar
Default Anybody have Fastbrakes upgrade?
I bought my fastbrake kit several years ago when they first started out. I was wondering if anybody knew the part number or what vehicle the 11" Front and Rear rotors came from?
Old Nov 18, 2003 | 10:11 PM
fastfour's Avatar
Default Re: Anybody have Fastbrakes upgrade? (S-Type1)
The front rotor is the Prelude VTEC rotor. The rear I believe came from an older gen 300ZX.
Zach
Old Nov 19, 2003 | 08:05 AM
owen_the_soyboy's Avatar
Default Re: Anybody have Fastbrakes upgrade? (fastfour)
on some Fastbrakes setups the 11" front rotor is a VW corrado rotor, possibly only the VR6 corrado.
make sure you know what you have before you get new parts
Old Nov 19, 2003 | 08:59 AM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastfour &raquo;</TD></TR><TR><TD CLASS="quote">The front rotor is the Prelude VTEC rotor. The rear I believe came from an older gen 300ZX.
Zach</TD></TR></TABLE>
wrong fronts are not prelude rotors.....
they are.....hmmm should i tell.....89-90 vw corrados
Old Nov 19, 2003 | 10:11 AM
S-Type1's Avatar
Default Re: Anybody have Fastbrakes upgrade? (chad)
I was thinking corrado too, but i just wanted to be sure.
on the application chart they have these listed:
89-91 Corrado (G60 - 1.8L)
92-95 Corrado (SLC - 2.8L VR6)
When i pull off my wheel, i should be able to find a part number of some sort anyway, right?
Old Nov 19, 2003 | 10:12 AM
Jaker's Avatar
The rotor is from the G60 Corrado, 1990 works. The VR6 had 5 bolt wheels.
Old Nov 19, 2003 | 10:19 AM
fastfour's Avatar
I've tried to fit a G60 rotor on the car and it doesn't work, close, but not quite correct. I've been told it is indeed a 4th Gen Prelude VTEC rotor.
Zach
Old Nov 19, 2003 | 10:23 AM
S-Type1's Avatar
fast4, do you have the fastbrakes integra caliper relocation kit or the willwood kit?
Modified by S-Type1 at 7:33 PM 11/19/2003
Old Nov 19, 2003 | 10:53 AM
some kits had the 92-96 Prelude VTEC rotor.
some kits had the ITR rotor with a Hub centric ring.
some kits had a G60 corrado rotor.
depends on what kit you got, mainly what knuckles you are bolting the kit up to... and what calipers you will be using.
Old Nov 19, 2003 | 10:55 AM
fastfour's Avatar
I have the 11 inch 1 piece rotor upgrade for a 1994 Civic EX and am damn near positive it is the 4th Gen Prelude VTEC rotor. I tried fitting the corrado rotor and it did not fit.
Old Nov 19, 2003 | 11:08 AM
rambler's Avatar
New User
Type R kit (Milled ITR calipers on 92-00 Si or EX uprights).... According to the man himself are 95 Prelude VTEC rotors redrilled to 4X100.
Nash
Old Nov 19, 2003 | 12:12 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastfour &raquo;</TD></TR><TR><TD CLASS="quote">I've tried to fit a G60 rotor on the car and it doesn't work, close, but not quite correct. I've been told it is indeed a 4th Gen Prelude VTEC rotor.
it depends
is the fastbrake wilwood caliper setup for CIVIC CX car or INTEGRA car?
fyi
corrado rotors will not fit on to integra knuckles/spindles so that would mean that the prelude vtec rotors were used for this setup...(just tried it out since i have both knuckles/spindles and both rotors sitting here....
Old Nov 19, 2003 | 12:13 PM
chad's Avatar
Moderator
Default Re: Anybody have Fastbrakes upgrade? (rambler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rambler &raquo;</TD></TR><TR><TD CLASS="quote">Type R kit (Milled ITR calipers on 92-00 Si or EX uprights).... According to the man himself are 95 Prelude VTEC rotors redrilled to 4X100.
Nash</TD></TR></TABLE>
correct....
Old Nov 19, 2003 | 12:17 PM
S-Type1's Avatar
redrilled meaning there were originally 5 lug holes which had new holes to accomodate for a 4x100 pattern, correct? My current rotors only have a 4x100 lug pattern.
Just FYI, my setup is a 92 civic Si w/ 94 integra calipers, relocation kit and 11" Brembo slotted rotors.
Old Nov 19, 2003 | 12:33 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S-Type1 &raquo;</TD></TR><TR><TD CLASS="quote">redrilled meaning there were originally 5 lug holes which had new holes to accomodate for a 4x100 pattern, correct? My current rotors only have a 4x100 lug pattern.
Just FYI, my setup is a 92 civic Si w/ 94 integra calipers, relocation kit and 11" Brembo slotted rotors.</TD></TR></TABLE>
not sure which rotors those are then....i'm pretty sure that year 92 or newer lug pattern was 4x114.3
Old Nov 19, 2003 | 12:54 PM
BluGTIVR's Avatar
Corrado G60 rotors do no have the correct offset, same with the VR6 rotors, wrong offset, I believe Zach is correct.
Old Nov 19, 2003 | 03:26 PM
Jaker's Avatar
Default Re: Anybody have Fastbrakes upgrade? (BluGTIVR)
I had one of Brian's 11" kits on my 98 Civic hatch, and they used Teg (non-ITR) calipers and most definitely 90 Corrado G60 4x100 rotors.
Old Nov 19, 2003 | 03:51 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BluGTIVR &raquo;</TD></TR><TR><TD CLASS="quote">Corrado G60 rotors do no have the correct offset, same with the VR6 rotors, wrong offset, I believe Zach is correct. </TD></TR></TABLE>
well the offset can be compensated by the brackets that are included with the kit....i have vw corrado rotors on now....and they fit fine, so i know they are the right offset
Old Nov 19, 2003 | 04:01 PM
fastfour's Avatar
For the 5th gen civic coupe EX (which is what I have that came w/ 10.3 inch brakes) the Corrado rotors will not fit, period. I have tried to bolt them up and they do not work. I've put rotors on my car more than a few times and these would absolutely not work. The kit I have from fastbrakes.com is the Accord Wagon caliper (or ITR, same part #) 11 inch kit that uses 4th Gen Prelude VTEC rotors. CX/DX cars I believe come w/ different front brakes and my not use the same set up I have.
The 11.4 inch big rear brake kit uses the stock rear caliper w/ a braket to relocate it and I believe uses and older gen 300ZX rotor.
We'll get this ironed out eventually.
Zach
Old Nov 19, 2003 | 04:05 PM
743power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastfour &raquo;</TD></TR><TR><TD CLASS="quote">For the 5th gen civic coupe EX (which is what I have that came w/ 10.3 inch brakes) the Corrado rotors will not fit, period. I have tried to bolt them up and they do not work. I've put rotors on my car more than a few times and these would absolutely not work. The kit I have from fastbrakes.com is the Accord Wagon caliper (or ITR, same part #) 11 inch kit that uses 4th Gen Prelude VTEC rotors. CX/DX cars I believe come w/ different front brakes and my not use the same set up I have.
Do your rotors have more than 4 stud holes on them? If so, they're prelude or type R rotors. If not, they are not prelude rotors. 92-96 preludes had 4x114.3 bolt pattern. 88-91 had 4x100, but they didn't have 11" rotors. I had the 11" front kit on my old 95 cx, and the rotors were 4x100, and I have been told by Brian that they are Corrado rotors.
Old Nov 19, 2003 | 04:08 PM
lustedp's Avatar
Are there any 11" front rotors and 10" rears that will simply bolt up to an integra?
Old Nov 19, 2003 | 04:33 PM
S-Type1's Avatar
Default Re: (lustedp)
considering the fact that the caliper relocation kit offsets the brake caliper, and my current rotors do not have any other lug patterns in them, i'm leaning towards chad's corrado brake rotors
Modified by S-Type1 at 1:54 AM 11/20/2003
Old Nov 19, 2003 | 04:43 PM
fastfour's Avatar
Default Re: (S-Type1)
I don't have corrado rotors!!!!!! Read my posts above. Corrado rotors may fit cx/dx hubs, but they absolutely do not fit onto EX hubs.
Old Nov 19, 2003 | 04:55 PM
S-Type1's Avatar
Default Re: (fastfour)
mind if i edit my previous posts
Old Nov 19, 2003 | 05:01 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastfour &raquo;</TD></TR><TR><TD CLASS="quote">I don't have corrado rotors!!!!!! Read my posts above. Corrado rotors may fit cx/dx hubs, but they absolutely do not fit onto EX hubs.</TD></TR></TABLE>
then i know of NO PRELUDE VTEC rotors that had ONLY a 4x100 bolt pattern....all ludes after 92 were 4x114.3
dude we are just trying to help you out....
what caliper do you have?
is it possible you just have an integra rotor and caliper?
