New Swap / What should be replaced?
Old Nov 18, 2003 | 07:19 PM
plusONE jboy's Avatar
Default New Swap / What should be replaced?
When you get a new swap, what parts should you replace right away?
Clutch, timing belt, water pump, spark plugs/wires..
What else should be replaced?
Old Nov 19, 2003 | 04:48 AM
VTECVillain's Avatar
Default Re: New Swap / What should be replaced? (5thgenh4tch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgenh4tch &raquo;</TD></TR><TR><TD CLASS="quote">When you get a new swap, what parts should you replace right away?
What else should be replaced? </TD></TR></TABLE>
All of those are a good idea. You can also change the oil pan and valve cover gaskets, distributor cap, rotor button, PCV valve, fuel filter, etc. It just depends on how much $ you have to work with and/or how **** you are. Some people will rebuild it right off others drop them in as is and go, somewhere in there is a happy medium.
Old Nov 19, 2003 | 08:55 AM
Default Re: New Swap / What should be replaced? (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">
All of those are a good idea. You can also change the oil pan and valve cover gaskets, distributor cap, rotor button, PCV valve, fuel filter, etc. It just depends on how much $ you have to work with and/or how **** you are. Some people will rebuild it right off others drop them in as is and go, somewhere in there is a happy medium. </TD></TR></TABLE>
Well i forgot to mention is a 2001 B18B1, should I really be replacing all of the parts?
Old Nov 19, 2003 | 10:28 AM
eyeamvic's Avatar
Do it all now, who knows when the last time they were replaced. At least this way you'll know when it was done and when you should do it again. A lot of the parts aren't expensive like the gaskets, caps, pcv valve, etc...
Old Nov 19, 2003 | 11:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgenh4tch &raquo;</TD></TR><TR><TD CLASS="quote">Well i forgot to mention is a 2001 B18B1, should I really be replacing all of the parts? </TD></TR></TABLE>
If it's an 01 motor that has been taken care of, chances are little if any of those parts will need to be replaced. Just use your best judgment and inspect everything. Anything that looks slightly worn or anything, just replace those parts.
Old Nov 19, 2003 | 08:52 PM
If it's an 01 motor that has been taken care of, chances are little if any of those parts will need to be replaced. Just use your best judgment and inspect everything. Anything that looks slightly worn or anything, just replace those parts.</TD></TR></TABLE>
Thanks..
Old Nov 19, 2003 | 09:37 PM
hondaZvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote"> somewhere in there is a happy medium. </TD></TR></TABLE>
i thought i was getting close to the end of the money pit.... but it seems its never ending... i dont think ill ever find my happy place... oh well...
crxpwr1
Jul 17, 2006 10:11 PM
spnbb2
Nov 26, 2004 12:18 PM
alleyezonme
Apr 8, 2004 08:26 PM
Behan
Jul 8, 2003 02:09 PM
whitehatch11
May 8, 2003 07:25 AM
