no spark? tried it alll.......
Old Nov 18, 2003 | 05:17 PM
racerboyb18c1's Avatar
Default no spark? tried it alll.......
the ignition fuse is good new plugs , wires are good, tried 3 ecu's , still no spark, i went throught the checklist in the chiltons for checking the voltage but it doesnt say what the voltage is supposed to be, also we went through 2 distributers , ne links would be supportive towards checking voltage and what voltage should be ? ne ideas thanks
Old Nov 18, 2003 | 05:55 PM
flat-blk-HB's Avatar
Default Re: no spark? tried it alll....... (racerboyb18c1)
Is this a recent swap or just stopped getting spark? Are you getting fuel? Have you checked all your grounds..(one on the thermostat housing) Check your main relay under the dash by the hood popper..Listen for a click while turning the key on...
Old Nov 18, 2003 | 05:58 PM
Default Re: no spark? tried it alll....... (flat-blk-HB)
it was running and just stopped
ran for bout a week then decided to be a bitch , has fuel but no spark at the wires , no i havnt checked the relay and yes all grounds are good
Old Nov 18, 2003 | 06:10 PM
JONBLAZE55555's Avatar
where did you get the distributers???
Old Nov 18, 2003 | 06:12 PM
Default Re: no spark? tried it alll....... (JONBLAZE55555)
from running motors
Old Nov 18, 2003 | 06:18 PM
are u getting power to the distributer?
Old Nov 18, 2003 | 06:23 PM
coil has power.
Old Nov 18, 2003 | 06:28 PM
b20bvtec'd's Avatar
If you replaced your distibutor with a complete different one this does not apply but if not check the coil. I've seen them spark and not start the car, changed to a new one worked fine.
Old Nov 18, 2003 | 06:54 PM
Default Re: no spark? tried it alll....... (b20bvtec'd)
what bout the main relay ne one know how to check?
Old Nov 18, 2003 | 07:46 PM
well we replaced the main relay still no fire
hey man
Jan 10, 2011 02:28 PM
Crossbreeder
Aug 16, 2010 05:52 AM
xtegb16x
16
Dec 29, 2008 10:28 PM
slvrcvc93
Apr 28, 2007 06:52 PM
91crxracer
Aug 26, 2006 02:05 AM
