Charging System Light aka Battery Light
Old Nov 18, 2003 | 03:56 PM
mntdewred's Avatar
Default Charging System Light aka Battery Light
1998 Honda Civic EX D16Y8 Stock 87,XXX miles 5SPD 87 Octane
Since last Sunday, November 16, 2003, I've noticed my Charging System Light coming on and off occasionally. I went to Autozone to have them check my battery and alternator, they said they were fine. I then went to Advanced Auto Parts for a second opinion, and they said my alternator and battery were fine.
I have also noticed that the light comes on when the car is cold or semi-cold (not completely warmed up yet). Hopefully you all can imagine this; when the car is at idle, 200rpm, the light is at full illumination. When I rev the engine slowly, the light starts to fade away and stays off when I'm driving normally (street or highway). Any suggestions?
Besides my battery light problem, can anyone shed some light as to why I idle so low? When I'm sitting at a light, I idle so low the car shakes and seems like it wants to die...Any suggestions??
TIA
Old Nov 18, 2003 | 05:10 PM
PHiZ's Avatar
Default Re: Charging System Light aka Battery Light (mntdewred)
Try replacing your grounding wires. I reccomend tinned-copper from like a boat stoe or something, cause it doesn't wick in water lick copper does.
We had this problem on a 91 CRX, but the ECU was intermittantly bad, is SEEMED to fix the problem.
-PHiZ
dipsettkid5
Apr 26, 2016 03:48 PM
aalb1
Aug 5, 2013 09:47 AM
r b k a
14
Jan 4, 2010 02:08 PM
thecorey
Feb 20, 2009 06:04 PM
return_2020
Aug 27, 2005 07:07 PM
